Author Topic: No clocks  (Read 2687 times)
Kylegtt
No clocks
« on: 23:02, Fri 23 December 2011 »
Put my head and everything back together after changing gasket, and i have no ignition lights or no motion in clocks (revs, fuel reading) etc, everything else works though like full beams, side lights.. bit stuck here
Yes i still go to school! And had 3 R5\'s..
Re: No clocks
« Reply #1 on: 23:28, Fri 23 December 2011 »
Does the car crank over?
Kylegtt
Re: No clocks
« Reply #2 on: 23:40, Fri 23 December 2011 »
yea mate
Re: No clocks
« Reply #3 on: 10:54, Sat 24 December 2011 »
The only wiring i can think of that would of been affected by removing the cylinder head is one of the earth cables.
Either that or you have knocked something somewhere, or it could be something completely random and it's just coincedence that you have just changed the head.
Re: No clocks
« Reply #4 on: 11:06, Sat 24 December 2011 »
Sounds like a fuse to me.
there is a fuse in the passenger side footwell marked STOP.
Change it and check.
Happened with mine ..
Kylegtt
Re: No clocks
« Reply #5 on: 11:55, Sat 24 December 2011 »
Ok cheers mate will do that in a little while and get back to ya
Kylegtt
Re: No clocks
« Reply #6 on: 23:38, Tue 27 December 2011 »
Still no clocks!!! any suggestions??
Re: No clocks
« Reply #7 on: 00:41, Wed 28 December 2011 »
Sounds like a simple wiring fault mate, does car start?
Kylegtt
Re: No clocks
« Reply #8 on: 22:35, Wed 28 December 2011 »
gonna see if it starts tomorrow cause i just bought petrol this evening so im going to fire her up tomorrow and see what happens
