Author Topic: fuel pump relay info  (Read 2669 times)
paulk
« on: 01:59, Fri 16 December 2011 »
would a faulty fuel pump relay stop power to the aei unit ? thanks
Re: fuel pump relay info
« Reply #1 on: 08:09, Fri 16 December 2011 »
No, it would stop power to fuel pump,  have you checked the relay beside the AEI in the scuttle?
paulk
« Reply #2 on: 09:29, Fri 16 December 2011 »
yes cheched and changed every thing , still cant get power to the aeu unit , so pump wont fire and no spark ..
« Reply #3 on: 20:55, Fri 16 December 2011 »
Is it case you not getting spark or you not got 12v's going to the AEI unit?
paulk
« Reply #4 on: 22:50, Fri 16 December 2011 »
yes no spark and no 12v to the aei
« Reply #5 on: 09:16, Sat 17 December 2011 »
Loop the AEI relay out and see if you get power and spark then, also check the earth wire for the unit too, see if its makes good contact and there no breaks
paulk
« Reply #6 on: 15:38, Sat 17 December 2011 »
is the relay the black on next the the unit in the scutle ?
« Reply #7 on: 16:28, Sat 17 December 2011 »
Quote from: "paulk"
Yes thats right
paulk
« Reply #8 on: 19:17, Sat 17 December 2011 »
bridged the back of that realay and it starts , seems theres no power to the centre yellow wire at least im getting some where now thanks mate
