Author Topic: exhaust stabilising brackets  (Read 3060 times)
big@l
« on: 19:51, Sun 04 December 2011 »
Hi guys,
this may be a bit of an odd 1, but today I have spent most of the day trying to fit a new (well 2nd hand) turbo downpipe to a stainless steel exhaust.
My problem is this, I can not work out which way the bolts go - from the downpipe to the front section of the exhaust, and which way and where the stabilising brackets fit to the engine.
Can any of you fine fellas enlighten me, and if poss would you be able to post a pic so I can see, as an explanation might get lost in translation
cheers in advance
Al
big@l
Re: exhaust stabilising brackets
« Reply #1 on: 16:52, Sat 24 December 2011 »
Ok Gents,
I knew it would be a tall order, but if any of you are under the bonnet over the Christmas break can you post a pic for me
ta very much
oh and happy Christmas :D
« Reply #2 on: 00:49, Sun 25 December 2011 »
I'm sure on mine the bolts go down through the downpipe, then on the centre section side you have the springs, washers and nuts.
big@l
« Reply #3 on: 18:41, Tue 27 December 2011 »
yep that sounds about right, I went along to the lads at CGB to buy these and he showed me how to fit them on an engine, I wish I had a taken a photo at the time!! but that was over a month ago now and I can't remeber how it goes together!   :?
big@l
« Reply #4 on: 19:41, Wed 11 January 2012 »
Ok lads and lasses,
I have posted a pic on the Facebook group page, that can be found here
http://www.facebook.com/groups/187997899309/
big@l
« Reply #5 on: 22:01, Thu 12 January 2012 »
now then gents, I have almost got this sorted....what a T$&t of a job it is, or is it just me, anyhow it is almost done   :D
big@l
« Reply #6 on: 21:31, Fri 13 January 2012 »
Does anyone know what size bolt is used to go in the back of the block for the main bracket M8 M10?  :?
ta
« Reply #7 on: 23:05, Fri 13 January 2012 »
The bolts that hold the bracket to the engine?
I think there M-8, i'm sure i remember using a 13mm socket on them, or was it 13mm socket for the downpipe connection and 10mm socket for the bracket (M6 bolt)?
It's one of the above. I'm almost certain it isn't as large as M10.
big@l
« Reply #8 on: 19:59, Sat 14 January 2012 »
yep Ash, M8
exhaust and brackets now fitted, not the easiest of jobs to do when everything is sat at about 0 degrees c and your hand sticks to every metal object it comes into contact with  :shock:
