Author Topic: omex rev limiter and launch control  (Read 5833 times)
Ruske
« on: 23:15, Mon 07 November 2011 »
http://www.omextechnology.co.uk/page2.html
has anybody installed it on his GTT?
are there any cons?
how to connect this to the coil?
i'd like to hear some of your experiences...
thx
Re: omex rev limiter and launch control
« Reply #1 on: 00:11, Tue 08 November 2011 »
I just installed an armtech revlimiter today. It has flat shifting capability but I didnt get the switch for it unfortunately
Launch controll would be awesome B-)
Was really easy to install the armtech device, in this pic you can see where I mounted it on the aei unit.
It connects to the coil +tve and -tve, with a ground also.
I can get you another pic which shows exactly where you connect the wires to if you like
Ruske
« Reply #2 on: 00:39, Tue 08 November 2011 »
yes i'd like a more detailed pic, if you can provide me
thanks
« Reply #3 on: 16:48, Tue 08 November 2011 »
here you go, .......this is what I used as a guide to connect the wires
« Reply #4 on: 18:57, Tue 08 November 2011 »
When i fitted an Armtech rev limiter i removed the coil and soldered the 2 wires onto the contacts the coil pushes into.
Or, as above, you could drill the plastic to uncover the one connection.
Ruske
« Reply #5 on: 19:49, Tue 08 November 2011 »
tubby, you are my savior...
thank you very much!!!
thx also to you ash
