Author Topic: Alternator belt  (Read 1481 times)
danielmk323
Alternator belt
« on: 10:54, Sun 06 November 2011 »
Hi guys i have a problem my alt belt keep truing up side down on the pules and some times it pops out when hard take off any tips
Re: Alternator belt
« Reply #1 on: 14:13, Sun 06 November 2011 »
I'm going to assume it's been correctly tensioned?
Check all 3 pulleys run straight and are nice and tight, if any one has been fitted off centre or has to much play it could cause the belt to run wonky.
Check the bolt that holds the alternator to the engine block is tight, when i first had mine that bolt was loose and that kept throwing the belt off.
Failing that, the belt might just be badly worn.
danielmk323
Re: Alternator belt
« Reply #2 on: 16:07, Sun 06 November 2011 »
i fond the problem tanks for the help
