Author Topic: clutch cable  (Read 1520 times)
crookston
clutch cable
« on: 17:44, Sat 05 November 2011 »
Hey.
Fitted a new clutch cable to the car today, but when I put the clutch in it fails on the ratchet and falls straight to the floor. Am i correct in saying that the ratchet on top of the pedal to the self adjuster is on a cam and has to be set up correctly to stop this happening?
Cheers
Jamie
Re: clutch cable
« Reply #1 on: 22:12, Sat 05 November 2011 »
You are correct. It needs adjusting.
Re: clutch cable
« Reply #2 on: 23:45, Sat 05 November 2011 »
It's a fiddly little thing.
At the top of the pedal is a small plastic stop. I find that by pulling that off i can get the pedal to lift higher and that seems to help with the adjuster. I then put the stop back in place.
crookston
Re: clutch cable
« Reply #3 on: 20:07, Sun 06 November 2011 »
Thanks for that. I'll give it another go
