Author Topic: engine cooling fan motor relay + el question  (Read 4014 times)
NorwegianGTE
« on: 23:05, Fri 04 November 2011 »
where can i find the engine cooling fan motor relay?
another question: i don't have electric windows but in the centre console there are plastic trims/caps in stead of buttons. however there are wires underneath these plastic caps. is the car pre-wired ? :)
thanks!  :)
Re: engine cooling fan motor relay + el question
« Reply #1 on: 23:37, Fri 04 November 2011 »
Not sure if all the relays under the bonnet are the same but when i got stuck i swapped the one for the horn to get the fan going in traffic.
I'm sure there not anything special, a half decent motor spares shop should have something suitable.
denty225
« Reply #2 on: 13:30, Sat 05 November 2011 »
Very informative Ash, but I think he meant where on the car is the relay!
NorwegianGTE
« Reply #3 on: 21:53, Sat 05 November 2011 »
yes that's right :) i wondered where the relay is located. under the bonnet? :)
« Reply #4 on: 23:48, Sat 05 November 2011 »
Ah! I miss-read it, i thought he said where can i find a relay.
It's under the bonnet. In the same area as the radiator fan switch, i might be dangling down the front of the alternator somewhere.
I'm sure if you follow the wiring from the radiator fan switch it should lead you straight to it.
NorwegianGTE
« Reply #5 on: 10:32, Sun 06 November 2011 »
Thanks Ash ! :) have a great sunday
nick1983
« Reply #6 on: 19:04, Sun 06 November 2011 »
Most cars tend to come pre wired as manufacturers find it cheaper to just use one loom than make different ones. If your looking to put electric windows in I have the switches and a pair of motors in the shed that I am going to sell.
270 cam
Modified carb, large venturi
2.5in downpipe
large elbow
2.5in side exit
Paceintercooler
samco blue hoses
Green induction kit
T25 turbo
Forge actator
NorwegianGTE
« Reply #7 on: 19:56, Sun 06 November 2011 »
Cool! Send me a PM. Maybe we could work something out :)
NorwegianGTE
« Reply #8 on: 11:33, Mon 07 November 2011 »
