Author Topic: water pump issue  (Read 2227 times)
deepee
water pump issue
« on: 19:19, Wed 02 November 2011 »
can anybody tell me where this pipe is orginaly meant to go, some pikey who had the car before me has blocked it off for some reason
its a injection model not carb if it helps
Re: water pump issue
« Reply #1 on: 19:25, Wed 02 November 2011 »
Does the inlet manifold have any coolant pipes missing or blocked off?
If it's the same as a GTT, that spout would feed the manifold and carb. Maybe the hose split and it just never got sorted.
deepee
« Reply #2 on: 19:27, Wed 02 November 2011 »
thanks for the reply, im not sure i cant see nothing on the mani but im not sure where im looking to be honest, is it a problem it being blocked off?
« Reply #3 on: 23:00, Wed 02 November 2011 »
A quick flick through the Haynes shows that even none turbo engines have the base of the carb water cooled/heated.
Not sure about the injection model though, is there anything around the inlet manifold or throttle bodie that looks like it should have a hose connected?
Probably not a problem leaving it blanked off unless you have really bad idle etc in the colder mornings.
