Author Topic: What power for what money?  (Read 2598 times)
kidsrs
« on: 18:36, Thu 20 October 2011 »
Looking at getting back into r5 turbines, currently got a s1 rs turbo running 230hp so if i had a 5 id want similar power, how much would it cost and what sort of mods would be required?
Re: What power for what money?
« Reply #1 on: 19:57, Thu 20 October 2011 »
Depends if you want to do it yourself or not on cost
Parts wise you'll need good cam (Piper 285 kit is best)
T28 turbo of some description, you'll need to run fairly high boost (22-24psi)
Poss drop compression very slightly (only if needed)
Very light flywheel
Well jetted carb (not a grp A)
Ideally a 2 1/2" exhaust and downpipe
Front mount intercooler
Good fuel system, phase 1 pump or maybe surge tank set up
With it all set up right that will get you in the right area for 230bhp but may need a few slight tweeks here and there
DeanGT5
« Reply #2 on: 20:35, Thu 20 October 2011 »
That sounds a little like mine  8)
« Reply #3 on: 20:50, Thu 20 October 2011 »
My old campus engine was similar to that spec i wrote and i got 220bhp from it, the tungy was similar too and done 230bhp
« Reply #4 on: 07:51, Fri 21 October 2011 »
love the series 1 rs turbos mate ,i hope your keeping it aswell as the 5  :D
kidsrs
« Reply #5 on: 13:55, Fri 21 October 2011 »
Cheers for that, ill be keeping the s1 for the time being
