Author Topic: Fule pump loom wires  (Read 3572 times)
« on: 18:44, Thu 13 October 2011 »
yo guys this is the last niggely thing i have to do before i can turn the key and start my raider,
looking into getting a new loom, although on a string budget atm, so if it could be fixd it would help a little (inless the looms are a fiver)
 the problem is i thought there would only be 2 wires say orange brown just to fuel pump, but instead there are like 3 orange and maybe 2 green and a brown or summing, im not sure where the wieres should be going and if one orange wire dose go to the fuel pump how do i no if the orange that i might be holding is the right one??
thanks for the time guys  :D
nick1983
Re: Fule pump loom wires
« Reply #1 on: 22:03, Thu 13 October 2011 »
Have you no wiring at all from the fuel pump that you could trace back? I don't mind jacking mine up tomorrow afternoon and having a look. What about the wiring diagram in the Haynes?
270 cam
Modified carb, large venturi
2.5in downpipe
large elbow
2.5in side exit
Paceintercooler
samco blue hoses
Green induction kit
T25 turbo
Forge actator
Re: Fuel pump loom wires
« Reply #2 on: 22:36, Thu 13 October 2011 »
no wires on the underneath of the car atall, the guy who welded everything up was good at welding / taking things off, but not putting em back or letting me no what bits he had taken off what or where  :roll:  he did a very nice job of welding though  :mrgreen:
and i dident want to put any one out there way for it, just wounded if there was any people on here that might just happen to know these few wires  :oops:
p.s thank u very much for the offer  :D  :D
robx1r
« Reply #3 on: 04:28, Fri 14 October 2011 »
i would assume 2 wires for the pump and 3 for the sender, (i havent looked at the fuel pump on a 5 just going by most internal fuel pumps
think my pump is on the way out, so i have a walboro 255 to fire into it i can have a look see when i'm doing this
« Reply #4 on: 07:31, Fri 14 October 2011 »
The fuel pump only has two wires attached to it.
I suppose the best answer will be......which two wires are those.
« Reply #5 on: 09:34, Fri 14 October 2011 »
yeh its deffo 2 to the pump.. live and earth, but it still leaves me with 3 or 4 wires, u say senders, do u mean the bits in the tank?? and will i be having to drop the tank to fix this  :cry:
spoke to mike from turbo spears he said that there were wires for fuel pump then gauge senders for the clocks..
« Reply #6 on: 14:01, Fri 14 October 2011 »
well good news i just put my order in to mike for a new loomd and a few other bits, happy chappy now  :mrgreen:  next week i should be able to get it started...will i need to plug all the senders in and so on to get it woking or can i just run the car for a bit with the pump pluggd in?
thanks guys  :D
