Author Topic: no side repeaters  (Read 1824 times)
karlr5
no side repeaters
« on: 21:19, Mon 10 October 2011 »
i had some dodgy focus side repeaters on my 5 but i needed to change the bulb holders and since then i have no repeaters,ive checked the wiring,any other ideas people?the weird thing is the indicators act as normal meaning when a bulb is out they should flash faster?
Re: no side repeaters
« Reply #1 on: 21:26, Mon 10 October 2011 »
They should flash faster yes.
What part of the wiring have you checked?
nick1983
« Reply #2 on: 21:33, Mon 10 October 2011 »
i thought they only flashed faster if it was front or rear i dont think they do if it's the side repeaters?
270 cam
Modified carb, large venturi
2.5in downpipe
large elbow
2.5in side exit
Paceintercooler
samco blue hoses
Green induction kit
T25 turbo
Forge actator
karlr5
« Reply #3 on: 21:56, Mon 10 October 2011 »
ive only checked the wiring from the side repeater to under the wing
ben marks
« Reply #4 on: 00:20, Tue 11 October 2011 »
Quote from: "karlr5"
how have you checked the wiring do you hace a 12volt feed up there or did you do a continuity test from the plug at the front back to the side repeter if so it is possible to have continuity but no feed if the wiring is coroded in anyway as it breaks down, if ur front indicator is working the rest of the wiring is ok as it comes off the same plug (well on mine it does ) so would say you defo have a problem between the plug at the front to the side indicator?
