Author Topic: broken  (Read 3115 times)
nick1983
broken
« on: 10:47, Sun 02 October 2011 »
just been to the shops in my renault and just as i pulled up on the driveway it started tapping and there was a slight dinking noise every now and again and it sounded like it was only running on 3 cylinders and plumes of white smoke coming from the exhaust. anyone have anyideas on what ive broken?  :(
270 cam
Modified carb, large venturi
2.5in downpipe
large elbow
2.5in side exit
Paceintercooler
samco blue hoses
Green induction kit
T25 turbo
Forge actator
nick1983
Re: broken
« Reply #1 on: 11:26, Sun 02 October 2011 »
just took the plugs out got oil on plug number 1  :(
270 cam
2.5in downpipe
large elbow
2.5in side exit
Paceintercooler
samco blue hoses
Green induction kit
T25 turbo
Forge actator
Re: broken
« Reply #2 on: 16:06, Sun 02 October 2011 »
Did anything happen when you drove it, did you drive hard or easy?
nick1983
Re: broken
« Reply #3 on: 16:13, Sun 02 October 2011 »
it's running 17psi but i kept it more or less off boost didnt go past 4000 revs to be fair. didn't think i was driving particulerly hard. it;s ruined my day though.lol i'm assuming it's done a piston but i just wondered if anyone has any other ideas before i take the head off.
270 cam
2.5in downpipe
large elbow
2.5in side exit
Paceintercooler
samco blue hoses
Green induction kit
T25 turbo
Forge actator
nick1983
Re: broken
« Reply #4 on: 16:22, Sun 02 October 2011 »
oh and this is my engine spec
270 cam
2.5in downpipe
large elbow
2.5in side exit
Paceintercooler
samco blue hoses
Green induction kit
T25 turbo
Forge actator
Re: broken
« Reply #5 on: 19:27, Sun 02 October 2011 »
It does sound like a piston at fault, to be honest i would pull head off anyway and have alooks you soon see whats gone.
Just read your spec, i see you have large venturi carb. I'd be thinking of getting rid of that
nick1983
Re: broken
« Reply #6 on: 19:42, Sun 02 October 2011 »
Yeah I'm gonna nip the carb off tomorrow I think. What's up with the large venturi? A couple of people have said to remove it but havent really said why, would it not help to prevent it leaning off?
270 cam
2.5in downpipe
large elbow
2.5in side exit
Paceintercooler
samco blue hoses
Green induction kit
T25 turbo
Forge actator
Re: broken
« Reply #7 on: 20:48, Sun 02 October 2011 »
Enlarging the venturi your reducing the venturi action, i:e is not sucking as hard as standard so way roud this was to fit a larger main jet but this in itself cause other issues, overfueling off boost is very common one.To be honest in my opinion running a poorly jetted large venturi carb cause more problems them not, i've run some very quick times (12.3 being quickest) on a standard venturi and main jet without it leaning out top end.
nick1983
Re: broken
« Reply #8 on: 21:01, Sun 02 October 2011 »
That is a seriously quick time. So Id be better to go back towards a standard carb then? I'll have a look on cgb see if they have a standard Venturi. It did pop a little on slow down and downshift. I think I'm probably going to be quite busy with them lol. Do you do set ups and fueling where you work?
270 cam
2.5in downpipe
large elbow
2.5in side exit
Paceintercooler
samco blue hoses
Green induction kit
T25 turbo
Forge actator
Re: broken
« Reply #9 on: 21:08, Sun 02 October 2011 »
Quote from: "nick1983"
I would recommend standard venturi all the time, haven't used a large venturi in very long time
All you need is a new carb body, you could swap all your other bits over to it but it will need setting up correctly for the boost you want
Yeah i do all work on 5's mate, its a weekend thing i do so not main job.
nick1983
Re: broken
« Reply #10 on: 21:37, Sun 02 October 2011 »
Where abouts are you based? It's the raider I got off Dean so when I've done he work I could always nip it down to you with the wastegate penny open running no boost
270 cam
2.5in downpipe
large elbow
2.5in side exit
Paceintercooler
samco blue hoses
Green induction kit
T25 turbo
Forge actator
Re: broken
« Reply #11 on: 21:42, Sun 02 October 2011 »
I'm based in Aylesbury, Dean popped down today to collect his engine so could ask him how far it is if you live near him.
If you take it easy then shouldn't be any reason to take actuator arm off.
