Author Topic: Water in the oil.oil in the water.......  (Read 2919 times)
mgree10
« on: 08:56, Sun 02 October 2011 »
morning Gents,
me little 5 was showing signs of head gasket failure.However when stripping her down gasket seems ok?could this have been caused by leaking liner seals?....mark
Re: Water in the oil.oil in the water.......
« Reply #1 on: 16:08, Sun 02 October 2011 »
Either liner seals, cracked head or oil cooler in rad is leaking into water system.
I would say its one of the latter if your getting oil in the water.
mgree10
« Reply #2 on: 16:46, Sun 02 October 2011 »
thanks......also noted car had a ktec gasket on that showed no signs of compression and only one head bolt needed to be cracked,rest seemed to come away fairly easy?...cud it have been fitted poorly?.....mark
« Reply #3 on: 19:25, Sun 02 October 2011 »
Now that doesn't sound good at all, it may well have bee fitted poorly.
Its worth just checking everything before fitting it all back together just to make sure
« Reply #4 on: 09:48, Mon 03 October 2011 »
I had same symtomps with a crack in the oilway in the head.
Higher pressure in expansion tank
Mayo/Icecream in the expansion tank
No mix in the rocker cover.
Gasket was intact and looked fine.
mgree10
« Reply #5 on: 09:27, Tue 04 October 2011 »
thanks gents....best thing todo as youve said,check everything before i replace it,fit it all correctly,will keep yas updated,fingers crossed....mark
