Author Topic: fuel sender  (Read 1672 times)
karlr5
fuel sender
« on: 20:35, Wed 28 September 2011 »
does anyone know the easiest way to remove a fuel sender as mine is messin about so maybe a clean up or a replacement is in order,cheers
Re: fuel sender
« Reply #1 on: 20:38, Wed 28 September 2011 »
Easy matey, remove rear lower bench, undo connections 3 x pipes and 1 x wire connector block with 3 wires on.
Then you need to make a tool to undo the big black plastic retaining donut, I used a modified metal exhaust clamp and it fitted perfectly just a case after that of undoing it, and then you can pull the sender unit out.
karlr5
Re: fuel sender
« Reply #2 on: 21:00, Wed 28 September 2011 »
nice one james,how or what did you do to the exhaust clamp
Re: fuel sender
« Reply #3 on: 21:54, Wed 28 September 2011 »
Quote from: "karlr5"
I got a large one and just bent the ends out enough so it would fit nicely into the sender donut
