Author Topic: Boost  (Read 5489 times)
Re: Boost
« Reply #15 on: 22:19, Sat 01 October 2011 »
Quote from: "denty225"
Ok, so is standard boost 11-12 psi at carb top then?
More like 7-8psi carb top standard boost, been so long since I have had a standard 5 I can not properly remember
Re: Boost
« Reply #16 on: 22:38, Sat 01 October 2011 »
10PSI carb top, 7PSI carb base.
ben marks
Re: Boost
« Reply #17 on: 12:55, Sun 02 October 2011 »
So when fitting an after market boost gauge you run it off the carb base to get the vac as well ? So if i do up the boost a little wit out modifying the carb wot psi would be ok or would i have to mod the carb ?
Re: Boost
« Reply #18 on: 14:11, Sun 02 October 2011 »
Quote from: "ben marks"
So when fitting an after market boost gauge you run it off the carb base to get the vac as well ? So if i do up the boost a little wit out modifying the carb what psi would be ok or would i have to mod the carb ?
10psi carb base anything above really needs setting correctly, but saying that I would still get anoy increase in boost checked with afr setup
denty225
Re: Boost
« Reply #19 on: 15:07, Sun 02 October 2011 »
Where exactly do you take feed from the carb base then? I'm getting round to fitting my gauges so might as well do it right.
Re: Boost
« Reply #20 on: 15:37, Sun 02 October 2011 »
The vacum line that goes to the AEI it's actually on the inlet manifold just below were the carb bolts to
ben marks
Re: Boost
« Reply #21 on: 16:53, Sun 02 October 2011 »
Deleted
denty225
Re: Boost
« Reply #22 on: 21:09, Sun 02 October 2011 »
Cheers James
