Author Topic: pressure regulating valve.  (Read 1446 times)
nick1983
« on: 08:36, Sun 11 September 2011 »
how do i adjust the pressure valve at the rear to get more back braking for the mot?
270 cam
Modified carb, large venturi
2.5in downpipe
large elbow
2.5in side exit
Paceintercooler
samco blue hoses
Green induction kit
T25 turbo
Forge actator
Re: pressure regulating valve.
« Reply #1 on: 13:31, Sun 11 September 2011 »
Are you sure its the bias valve thats at fault before you start adjusting it, might be worth checking the condition of the discs, pads and calipers first as this is what normally causes poor braking on the rear
