Author Topic: turbo  (Read 3634 times)
nick1983
turbo
« on: 17:45, Fri 09 September 2011 »
i posted on here on monday about white smoke. some people said it was condensation in the exhaust but it has got worse so i whipped the exhaust wlbow off and its got quite a lot of oil in it so i'm guessing that the seals are buggered.  :( any other ideas that i could be missing?
270 cam
Modified carb, large venturi
2.5in downpipe
large elbow
2.5in side exit
Paceintercooler
samco blue hoses
Green induction kit
T25 turbo
Forge actator
Re: turbo
« Reply #1 on: 18:28, Fri 09 September 2011 »
Sounds like turbo has gone to me, time for rebuild.  Has the shaft got any play in it?
nick1983
Re: turbo
« Reply #2 on: 18:51, Fri 09 September 2011 »
no none whatsoever. dean had it rebuilt and the rear seal went straight away so i bought one of those with the extra bit and a heat shield but now it's smoking worse than ever and got oil in the exhaust.  :?
270 cam
2.5in downpipe
large elbow
2.5in side exit
Paceintercooler
samco blue hoses
Green induction kit
T25 turbo
Forge actator
Re: turbo
« Reply #3 on: 18:56, Fri 09 September 2011 »
When you rebuikd a turbo you normally have to change little more then just the seals, when turbos go there tends to be more wrong with them.
It'll need properly rebuilding mate, shaft checked and ground if needs be, new bearings and seals plus checking its all balanced too as this will kill a turbo quickly too
nick1983
Re: turbo
« Reply #4 on: 19:05, Fri 09 September 2011 »
i#m starting to realise the biggest pain is it's in for it's mot re-test on monday and they will never pass it smoking like it is. :?
270 cam
2.5in downpipe
large elbow
2.5in side exit
Paceintercooler
samco blue hoses
Green induction kit
T25 turbo
Forge actator
Re: turbo
« Reply #5 on: 19:12, Fri 09 September 2011 »
Quote from: "nick1983"
Yeah its abit hard to pass as they do check for smoke out exhaust, is anyone near you who can lend you tubo to get you through MOT?
nick1983
Re: turbo
« Reply #6 on: 19:41, Fri 09 September 2011 »
no not really  :lol: i'm just gonna strip ity down again clean it all out tow the car to them and hope it doesn't smoke too much. it only needs the back brakes testing this time maybe i'll get lucky
270 cam
2.5in downpipe
large elbow
2.5in side exit
Paceintercooler
samco blue hoses
Green induction kit
T25 turbo
Forge actator
tom
Re: turbo
« Reply #7 on: 23:24, Sun 11 September 2011 »
if it has left the test station it will need a full test buddy
Re: turbo
« Reply #8 on: 23:44, Sun 11 September 2011 »
Quote from: "tom"
Really? Depends on what it failed on.
It should only need testing on what it failed on, that's how it's always worked for me in the past.
nick1983
Re: turbo
« Reply #9 on: 02:32, Mon 12 September 2011 »
only a partial as it's being returned within the 10 working days so they just check what it failed on
270 cam
2.5in downpipe
large elbow
2.5in side exit
Paceintercooler
samco blue hoses
Green induction kit
T25 turbo
Forge actator
tom
Re: turbo
« Reply #10 on: 08:27, Mon 12 September 2011 »
at work (im a tech) if the vehicle leave's the test station then we have to perform a full test regardless of milage because you dot know what the car has been doing since it left minor incident etc
nick1983
Re: turbo
« Reply #11 on: 18:06, Mon 12 September 2011 »
cars now got  12 month ticket on it  :D  :D  :D  :D  :D  now the hunt is on for a new turbo  :cry:  :cry:  :cry:  :cry:
270 cam
2.5in downpipe
large elbow
2.5in side exit
Paceintercooler
samco blue hoses
Green induction kit
T25 turbo
Forge actator
