Author Topic: T25 Turbo  (Read 4245 times)
Jeff Ninebar
T25 Turbo
« on: 15:46, Tue 06 September 2011 »
I just picked up 2nd hand Turbo very cheap, its a Turbo Technics stage 3 T25/T25 .48 A/R comp and .49 A/R exhaust.
Does any one have any experience with this unit, I was looking for a T25/T2 for normal road driving on the standard cam, but as it was cheap I went for it. Doing some research I have read that a cam change may be needed with the T25/T25? how laggy are these units as well?
I also want to get some nice braided hose to go on the top turbo feed, what size fitting is it?
DeanGT5
Re: T25 Turbo
« Reply #1 on: 16:51, Tue 06 September 2011 »
I think this is the one that was for sale on here, The connectors are different so you may need to go down to your local pirtec or pipe place and get one made up. You should be ok running it with a standard cam
Re: T25 Turbo
« Reply #2 on: 20:07, Tue 06 September 2011 »
I've had a couple of Rover T25's, i think the spec is about the same. Im sure mine had a .49 rear.
It will be quite laggy, i remember full boost being around 4'000RPM, so you definately need to keep it screaming to get the most from it. I ran mine with a standard cam without issues, something like a 285 will keep making power beyond 6'000RPM.
On a positive note, sitting on the motorway @ 70MPH, the turbo didn't read anything. Possible fuel economy gains!  :D
juha5gtt
Re: T25 Turbo
« Reply #3 on: 21:06, Tue 06 September 2011 »
Hmm.. how high rpm full boost comes like t25 rear .64 then? If .49 comes about 4k rpm.
And have anyone experience with GT2554R with .64 rear? I read somewhere that full boost comes 1k rpm lower compared to older t25 with .64 or was it .62. And do i need 285 cam with GT2554R?
regards,
Juha
Re: T25 Turbo
« Reply #4 on: 21:25, Tue 06 September 2011 »
Don't go for .64 rear, its too large. I have tried it on my tungy 5 recently and don't get full boost untill 5000rpm and thats with a 285 cam dialed in at 112deg.
Now my turbo is T28 off the 200SX so not too sure if the wheel trim i'm using is different to the wheel trim you have as this may make difference but from years of experinece i would stick with the .49 rear.
Also the .49 can spool up sooner then 4000rpm, using smaller wheels will help this and if your engine breaths better this will help too.
juha5gtt
Re: T25 Turbo
« Reply #5 on: 21:32, Tue 06 September 2011 »
is it GT2554R with .64 fast spooler becouse dual ball bearings?
Any experiences anyone with this model?
Juha
Re: T25 Turbo
« Reply #6 on: 17:08, Wed 07 September 2011 »
Quote from: "juha5gtt"
Juha
You may find it spools every so slightly better but it will all depend oin what cam, exhaust and exhaust elbow you are using.
Jeff Ninebar
Re: T25 Turbo
« Reply #7 on: 18:04, Wed 07 September 2011 »
Quote from: "DeanGT5"
yep, just found the sale add in the classifieds, it is that unit. not sure how the boost was being lost as there doesn't seem to be anything wrong with the turbo mechanically. the square exhaust section looks like it was leaking air around the gasket as there is black soot lines in one corner so this may have been something to do with it...find out this weekend when i try fitting it :lol:
really need to know the thread size for the turbo oil feed, anyone? will the standard T2 feed fit?
Re: T25 Turbo
« Reply #8 on: 18:09, Wed 07 September 2011 »
Quote from: "Jeff Ninebar"
yep, just found the sale add in the classifieds, it is that unit. not sure how the boost was being lost as there does seem to be anything wrong with the turbo mechanically. the square exhaust section looks like it was leaking air around tghe gasket as there is black soot lines in one corner so this have been something to do with it...find out this weekend when i tryu fitting it :lol:
You need to get the turbo and the oil feed pipe down to your local pirtek and ask them to find you an adaptor
Jeff Ninebar
Re: T25 Turbo
« Reply #9 on: 18:51, Wed 07 September 2011 »
i was hopeing to avoid a trip to the shops and do it all online as i'm working away all week but thanks for the info i'll find my local pirtek on saturday.
