Author Topic: white smoke  (Read 3539 times)
nick1983
white smoke
« on: 19:23, Mon 05 September 2011 »
took the raider in fot it's mot today it failed on the back brakes not working quite right, no problem there. The only other thing it got was an advisory for white smoke coming from the exhaust, not sure where the problem is as it is clearly puffing out but i dont think the water level has dropped. any ideas? :?
270 cam
Modified carb, large venturi
2.5in downpipe
large elbow
2.5in side exit
Paceintercooler
samco blue hoses
Green induction kit
T25 turbo
Forge actator
fordy
Re: white smoke
« Reply #1 on: 19:37, Mon 05 September 2011 »
could be turbo seal as it  sometimes comes out white out the back
DeanGT5
Re: white smoke
« Reply #2 on: 19:39, Mon 05 September 2011 »
Nick have a read on this thread. Sounds very similar. Could be because the car has been standing for a while.
viewtopic.php?f=10&t=7687&p=55171&hilit=white+smoke#p55171
nick1983
Re: white smoke
« Reply #3 on: 19:40, Mon 05 September 2011 »
i wondered this, replaced the back seal at the weekend though and it had had a rebuild just before
270 cam
2.5in downpipe
large elbow
2.5in side exit
Paceintercooler
samco blue hoses
Green induction kit
T25 turbo
Forge actator
Re: white smoke
« Reply #4 on: 19:41, Mon 05 September 2011 »
Maybe condensation in the exhaust??. Has the car been sitting a while without being run?
DeanGT5
Re: white smoke
« Reply #5 on: 19:44, Mon 05 September 2011 »
I would def drive it for a while as the weathers not been great and it was standing.
nick1983
Re: white smoke
« Reply #6 on: 19:45, Mon 05 September 2011 »
cheers guys i'll get the re-test done, got to wait until bloody monday, then give it a nice run to the ashby foalville show on tuesday and see how it is. it's boosting a treat and isn't overheating although i would like a cooler thermostat for the fan
270 cam
2.5in downpipe
large elbow
2.5in side exit
Paceintercooler
samco blue hoses
Green induction kit
T25 turbo
Forge actator
DeanGT5
Re: white smoke
« Reply #7 on: 19:46, Mon 05 September 2011 »
Im sure I have one in my many spares :lol:
I thought it was a low one in there?
nick1983
Re: white smoke
« Reply #8 on: 19:49, Mon 05 September 2011 »
no i don't think so, if you have stick it with the belt and ill come over with some money on monday when it's mot'd if you'll be  about. any news on your engine yet?
270 cam
2.5in downpipe
large elbow
2.5in side exit
Paceintercooler
samco blue hoses
Green induction kit
T25 turbo
Forge actator
DeanGT5
Re: white smoke
« Reply #9 on: 19:52, Mon 05 September 2011 »
Dont worry about it, you can have them.
Need to machine to the top of a piston off, is that something your dad could do?
Marks looking into it and seeing if he can get one done down there.
nick1983
Re: white smoke
« Reply #10 on: 19:55, Mon 05 September 2011 »
oh cheers dean  :D ,yeah he could do that, i don't see it being a problem i'll ask him later when i see him and let you know
270 cam
2.5in downpipe
large elbow
2.5in side exit
Paceintercooler
samco blue hoses
Green induction kit
T25 turbo
Forge actator
Re: white smoke
« Reply #11 on: 20:27, Mon 05 September 2011 »
Quote from: "nick1983"
Did your shaft have any play in it when you replaced the seals? Sometimes rebuilding a turbo isn't as straight forward as fitting new bits
DeanGT5
Re: white smoke
« Reply #12 on: 20:44, Mon 05 September 2011 »
Shaft was spot on when done, it did blow smoke again though after the rebuild, I spoke with the place I had the kit off and they said the shoulders can wear on the shafts causing the rear seal to leak (I didnt rebuild it, my mate from GGR did)
Re: white smoke
« Reply #13 on: 21:54, Mon 05 September 2011 »
Italian style tune up FTW
Re: white smoke
« Reply #14 on: 23:25, Mon 05 September 2011 »
Quote from: "andybond"
+1.
This seems to have cured my missfire BTW.  :lol:
