Welcome,
Guest
. Please
login
or
register
08:11, Fri 20 May 2022
Home
Help
Search
Login
Register
RENAULT5GTTURBO.COM
TECHNICAL ISSUES
Renault 5 GT Turbo
will pug205gti wheels fit my 5 ?
« previous
next »
Print
Pages: [
1
Author
Topic: will pug205gti wheels fit my 5 ? (Read 3126 times)
tom
150BHP Member
on:
22:09, Mon 29 August 2011 »
as per title thanks
Logged
Global Moderator
200BHP Senior Member
Re: will pug205gti wheels fit my 5 ?
Reply #1 on:
22:24, Mon 29 August 2011 »
No they have different stud pattern
Logged
tom
150BHP Member
Reply #2 on:
22:26, Mon 29 August 2011 »
hmmm wanting some different wheels but dont wanna spend too much and dont want anything too aftermarket looking
Logged
Global Moderator
Reply #3 on:
22:29, Mon 29 August 2011 »
Vauxhall and VW have same stud opattern just try keep et as close to standard as poss. You may need spigot rings or centre boring out to fit wheels on too from other cars.
Logged
tom
150BHP Member
Reply #4 on:
22:34, Mon 29 August 2011 »
so i can fit vw wheels on to my 5 ?
Logged
Global Moderator
Reply #5 on:
22:35, Mon 29 August 2011 »
Yes you can mate, some may need centre bore machined out as the diameter of it is smaller then Renault
Logged
nick1983
170BHP Member
Reply #6 on:
23:12, Mon 29 August 2011 »
what about looking for a set of cav gsi 15" slabs painted black they might look pretty good?
Logged
270 cam
Modified carb, large venturi
2.5in downpipe
large elbow
2.5in side exit
Paceintercooler
samco blue hoses
Green induction kit
T25 turbo
Forge actator
Global Moderator
Reply #7 on:
23:31, Mon 29 August 2011 »
Quote from: "nick1983"
They do look good on 5's.
There was one not far from me that had them fitted. They will need the centres machining out though.
Logged
nick1983
170BHP Member
Reply #8 on:
23:35, Mon 29 August 2011 »
Well I used to be into novas and they always suited them I figured they would look good as they are a similar shape. It's only a small skim off the centre isn't it? Not too sure how much the difference is.
Logged
270 cam
2.5in downpipe
large elbow
2.5in side exit
Paceintercooler
samco blue hoses
Green induction kit
T25 turbo
Forge actator
Print
Pages: [
1
« previous
next »
RENAULT5GTTURBO.COM
TECHNICAL ISSUES
Renault 5 GT Turbo
