Author Topic: stiff pedals ?  (Read 2743 times)
tom
stiff pedals ?
« on: 21:00, Sun 28 August 2011 »
rite is there a miricle cure for a bloody stiff clutch pedal and an even stiffer throttle and the cables and pedal box are free as a bird really confused ???
its a 1989 phase2 thanks
Re: stiff pedals ?
« Reply #1 on: 02:05, Mon 29 August 2011 »
Give it time, im sure most pedals on 5's are pretty stiff in comparison to modern cars, especially the clutch!!  Soon enough you will be used to it!!
Although I have heard of a soft pedal conversion for the clutch - not sure how it works though!!
Re: stiff pedals ?
« Reply #2 on: 09:53, Mon 29 August 2011 »
The clutch is fairly stiff, if you think it's too stiff it might be worth checking the cable isn't showing any signs of fraying. It's not uncommon for them to snap.
The throttle should be quite loose. Again check the cable but also check the throttle mech works smoothly on the carb.
The throttle also moves the accelerator pump jet on the carb, it's a rod held in with a small plastic grommit. I've known them break up and fall out, so check that moves smoothly as well. Last thing you want is the throttle jammed open.
tom
Re: stiff pedals ?
« Reply #3 on: 15:49, Mon 29 August 2011 »
sorted the throttle it was a sciezed choke cable and stiff as fook return spring
Re: stiff pedals ?
« Reply #4 on: 17:55, Mon 29 August 2011 »
What clutch do you have in the car?
tom
Re: stiff pedals ?
« Reply #5 on: 19:25, Mon 29 August 2011 »
not sure its deffo uprated
i bought the car assuming it was fairly standard but am revieling quie a few goodies lol
Re: stiff pedals ?
« Reply #6 on: 20:49, Mon 29 August 2011 »
If you have the Valeo clutch in there (Volvo 480 turbo one) they are always litle shiffer and snappy compared to a standard one. Only way to loose that feeling is to fit extended clutch arm or get use to it  :wink:
