Author Topic: set up  (Read 3014 times)
nick1983
set up
« on: 20:03, Fri 26 August 2011 »
hi all. i'm looking into getting my raider setup properly running wise and am looking to book it into a specialist. Prima is the nearest one to me and i was wondering if anybody has any experiance with them good or bad that they could tell me before i book it in. thanks people
270 cam
Modified carb, large venturi
2.5in downpipe
large elbow
2.5in side exit
Paceintercooler
samco blue hoses
Green induction kit
T25 turbo
Forge actator
Re: set up
« Reply #1 on: 20:23, Fri 26 August 2011 »
Old school tuning which means crappy old school grp A carbs. I have heard of some bad dealings from mates who have been into 5's for years.
DeanGT5
Re: set up
« Reply #2 on: 20:33, Fri 26 August 2011 »
Nick
The carb already has a enlarged venturi, I never checked the jets but it was spot on when I put it on the rollers. might be worth having a look first so you know what you've got.
fordy
Re: set up
« Reply #3 on: 20:35, Fri 26 August 2011 »
there maybe someone local with experience and the kit need to set these up and would save you alot of money
sounds like you just need a afr and det check and maybe tweak a jet or 2 and the timing if needed
Re: set up
« Reply #4 on: 22:25, Fri 26 August 2011 »
If it hads an enlarged venturi on there i'd be getting rid of that straight away
bluntyr5gtt
Re: set up
« Reply #5 on: 06:57, Sun 28 August 2011 »
best bet is to buy a decent afr kit and start from there, as mark says go back to standard venturi then back to standard main jet then work your way through the carb eg 2nd stage,air corrector and if needed a bigger needle valve.
its all trial and error fella i will be the first to say that i knew nothing about these cars a couple of years ago but it comes with time and help from fellow members like mark above is priceless :)
ported head
bjr downpipe/elbow
tubular manifold
fully rejetted carb
Ramair Induction Kit
cosworth 2wd Intercooler
Lowered 50mm
nick1983
Re: set up
« Reply #6 on: 08:10, Sun 28 August 2011 »
Ok then thanks for the help guys.  :)
270 cam
2.5in downpipe
large elbow
2.5in side exit
Paceintercooler
samco blue hoses
Green induction kit
T25 turbo
Forge actator
bluntyr5gtt
Re: set up
« Reply #7 on: 15:09, Sun 28 August 2011 »
no probs fella good luck and happy boosting
ported head
bjr downpipe/elbow
tubular manifold
fully rejetted carb
Lowered 50mm
