Author Topic: Anti perc fan  (Read 2235 times)
adscan
Anti perc fan
« on: 14:40, Fri 26 August 2011 »
I want to try running my car without the anti perc fan. What is the best way to make safe the wiring? I don't want to cut it out as I will want to use it in the future.
Can I just unplug the motor?
DeanGT5
Re: Anti perc fan
« Reply #1 on: 17:46, Fri 26 August 2011 »
Yes, just re-route the pipe which runs through the fan housing and remove the wiring end to end if you can
adscan
Re: Anti perc fan
« Reply #2 on: 13:30, Sun 28 August 2011 »
can i remove it without cutting?
DeanGT5
Re: Anti perc fan
« Reply #3 on: 13:42, Sun 28 August 2011 »
Yes, the pipe you need to disconnect, take the fan off then reconnect. if you want to keep the wires tape the ends up so the cant touch together or anything else.
