Author Topic: Brake problems  (Read 1290 times)
Dan5
Brake problems
« on: 19:21, Thu 25 August 2011 »
Hi,
I've recently fitted some 4 pot brakes to my car after bleeding the system a couple of time the brake pedal goes to the floor. I think my master cylinder may have had it.
Would it be worth fittingbigger bored master cylinder to suit the calliper?
Any help would be much appreciated
karlr5
Re: Brake problems
« Reply #1 on: 19:50, Thu 25 August 2011 »
try pulling or pushing the rear brake sensor it might of been closed when you first bled the system which means you might still have air in the system
fordy
Re: Brake problems
« Reply #2 on: 21:27, Thu 25 August 2011 »
silly question but easily over looked
are the bleed nipples at the top or bottom of the front calipers?
Dan5
Re: Brake problems
« Reply #3 on: 21:39, Thu 25 August 2011 »
The callipers have 2 nipples each both at the top.
I've bled the system a few times now and the pedal still travels to the floor.
fordy
Re: Brake problems
« Reply #4 on: 21:47, Thu 25 August 2011 »
are you locking the compensator lever to the front of the car when bleeding the rear brakes?
how are you bleeding the system manually or with an easy bleed kit?
Dan5
Re: Brake problems
« Reply #5 on: 22:00, Thu 25 August 2011 »
Yeah I've lock it forward. I've been bleeding them manually. I did have problem bleeding the front driver side calliper.
Do you think it could be something other then my master cylinder?
