Author Topic: Renault 5 raider f7p conversion on bike carbs...  (Read 2103 times)
01mlacey
« on: 01:33, Thu 25 August 2011 »
gathering all the bits to convert to f7p
not going turbo yet! so were guna run it on bike carbs
1st of all has anyone on here or know anyone thats running a similer set up?
and 2nd what sorta ignition parts were needed..
also is it a case the t piece method for fueling them
any info would be greatful
thanks in advance
01mlacey
Re: Renault 5 raider f7p conversion on bike carbs...
« Reply #1 on: 21:53, Fri 26 August 2011 »
No one... :roll:
« Reply #2 on: 22:22, Fri 26 August 2011 »
I can't think of anyone that has actually done bike carbs on a 16v unit, there prob is but maybe on the Clio clubs
Ignition side i'd say you'll be ok using the standard stuff , just wire the timing sensor and AEI unit up like the 5 so it does run through the 16v's redundant ecu
01mlacey
« Reply #3 on: 02:51, Sun 28 August 2011 »
Cheers man ill keep that in mind
ive not personally seen then on a 5
but ive seen many volvo 340s running f7p engines on bike carbs
but anyones input is much apreciated :D
