Author Topic: Nooooo!!!!!!!  (Read 4882 times)
DeanGT5
Nooooo!!!!!!!
« on: 20:01, Sat 20 August 2011 »
Well after a good day out at WRS at Silverstone im now home in a not to good mood.
Had to show a corsa VXR that the "old boys" still have the edge which I did with ease. Did about another 30 mile at a steady speed till the oil pressure gauge dropped, smoke through the vents and a clatter from the front!!
Think the big end bearings or something bottom end has pooped its pants!
Do I fix it or push it into the nearest quarry!!!
Re: Nooooo!!!!!!!
« Reply #1 on: 20:21, Sat 20 August 2011 »
Posibly done a piston too, think only way going to find out is pul it apart. What you need to do is see what caused it go to too and sort that out too.
DeanGT5
Re: Nooooo!!!!!!!
« Reply #2 on: 20:24, Sat 20 August 2011 »
I think im destined to live in the garage lol, possibly 130 then backing off? It had started to knock a little when cold.
I managed to nurse it home, it still had 2 bar of pressure
Oh I was thinking off popping down to see you Mark, may have to leave that for a while lol
megaflea
    • http://www.megaflea.net
Re: Nooooo!!!!!!!
« Reply #3 on: 22:49, Sat 20 August 2011 »
Hey dude i was checking out your motor down silverstone today,
and speaking to the  guy who had the mint black one
i left my 5 at home (clutch gave up last night when i left) boo
unlucky about the engine time for a rebuild :D
root@renault5gtt~]# echo "if you cant fix it" ; init 6 ; echo "it"
DeanGT5
Re: Nooooo!!!!!!!
« Reply #4 on: 16:52, Sun 21 August 2011 »
Took the engine out today and stripped the bottom end. Looks like contamination in the oil and scored bearings.
There seems to be scoring on the crank too
And some to the liner
There a few of one liner before someone ask if I have a six cylinder lol
Does anyone have a can of "Miracle engine rebuild"  :lol:
Re: Nooooo!!!!!!!
« Reply #5 on: 17:44, Sun 21 August 2011 »
I see a very knackered piston in there!
Thats your problem, it leaned out and the piston has niped up on the liner. Time for another piston/liner
DeanGT5
Re: Nooooo!!!!!!!
« Reply #6 on: 17:50, Sun 21 August 2011 »
Not good then!!! Ill pop it down to you when I get 5 mins.
Re: Nooooo!!!!!!!
« Reply #7 on: 17:52, Sun 21 August 2011 »
Quote from: "DeanGT5"
Thats cool mate
Re: Nooooo!!!!!!!
« Reply #8 on: 09:04, Mon 22 August 2011 »
Yeah, as Mark said, I did exactly the same on my old C1J, if you take that piston out I bet it looks a bit of a mess near the top  :cry:  It's got to hot & stuck to the liner wall, then it prob dumped the oil out somewhere, I had a catch tank, this overflowed & I lost all the oil, which also knackered my bottom end....
Re: Nooooo!!!!!!!
« Reply #9 on: 13:43, Mon 22 August 2011 »
Crikey Dean 130mph :lol:  I would be scared to go past 100mph in a GTT they get so light and rattle.  Did you keep and eye open on the afr's?
Re: Nooooo!!!!!!!
« Reply #10 on: 14:39, Mon 22 August 2011 »
I think he was too busy destroying a WRX scoob to notice ..
DeanGT5
Re: Nooooo!!!!!!!
« Reply #11 on: 08:37, Tue 23 August 2011 »
SteveL - Took the pistons out, one looks like its been out in the sun too long lol
No too much damage to the head and only a little to the other piston.
I think from now on ill stick below 100(KM)  :wink: or get a talking AFR gauge  :oops:
Dropped the engine of at Marks last night, hopefully should be done by dinner today  :lol:
At least its an excuse to repaint the engine bay and do the front bumper. Also need a clutch release bearing.
Re: Nooooo!!!!!!!
« Reply #12 on: 08:54, Tue 23 August 2011 »
Whoah ! That looks nasty dude !
Re: Nooooo!!!!!!!
« Reply #13 on: 23:02, Tue 23 August 2011 »
F**king hell.
That's impressive.  8)
denty225
Re: Nooooo!!!!!!!
« Reply #14 on: 23:07, Tue 23 August 2011 »
Oh yess, you done a proper job on that one!
