Author Topic: how to tell?  (Read 2589 times)
ben marks
how to tell?
« on: 23:42, Wed 27 July 2011 »
How do ya tell the difference between a phase one engine and a phase 2 thanks people
Re: how to tell?
« Reply #1 on: 01:10, Thu 28 July 2011 »
There is no difference i don't think.
Phase 2 will have a knock sensor fitted to the cylinder head, also the turbo oil drain is a different size.
Re: how to tell?
« Reply #2 on: 09:31, Thu 28 July 2011 »
There's a few other differences.
The header tank in a longer, flatter kind on a phase one, and the coolant pipes are different, you'll notice more by the water pump as there'll be no swirl pot and more bleed nipples.
The throttle cable goes to a pivot thingy on a phase one and has a shorter cable, where the phase two loops right round.
The phase one has extra bits on the exhaust manifold, which make it a pain to remove/tighten the nuts.
The aei unit will be engine side of the bulk head, unless it's been removed.
The oil return for the sump is smaller, and on early ones they were baffled.
There's a few other bits but they don't make a lot of difference.
ben marks
Re: how to tell?
« Reply #3 on: 11:00, Thu 28 July 2011 »
Ok thanks guys great help is there a way to tell a phase 2 shell to a phase 1 meaning if ya had a phase 1 body put someone put the phase 2 body kit on how could u no ?
Re: how to tell?
« Reply #4 on: 12:19, Thu 28 July 2011 »
Engine code is also another way to tell. 788 is later models
Re: how to tell?
« Reply #5 on: 12:21, Thu 28 July 2011 »
Quote from: "ben marks"
Reg plate of car is a pretty good way to work out what kit your car should have if its a D plate or older it would have been a phase 1, e - reg is crossover so would have phase 2 kit but some engine and internals of the car will still be phase 1, f reg and newer would be phase 2 painted kits
ben marks
Re: how to tell?
« Reply #6 on: 14:38, Thu 28 July 2011 »
Spot on thanks
Re: how to tell?
« Reply #7 on: 15:43, Thu 28 July 2011 »
Where in Bedfordshire are you? I'd come along to look at a few if you want someone to have a look over a few 5's with you.
ben marks
Re: how to tell?
« Reply #8 on: 01:02, Sat 30 July 2011 »
too late now mate got one the other day thanks for the thort tho
im in leighton buzzard but working in dustable
Re: how to tell?
« Reply #9 on: 01:16, Sat 30 July 2011 »
Cool not far at all. My sister lived over there in the new estate until a few weeks ago.
You'll have to come to some of the meets with us, next one is Wednesday evening if you're about?
ben marks
Re: how to tell?
« Reply #10 on: 01:24, Sat 30 July 2011 »
sounds good wheres it at its not on the road yet lol big prject ahead lol
Re: how to tell?
« Reply #11 on: 01:41, Sat 30 July 2011 »
I'll PM you buddy.
