start with a dry test first
engine up to temp
disconnect fuel pump relay
have a fully charged battery
remove all spark plugs
insert tester into first cylinder
throttle held wide open
crank over till gauge stops going any higher and read off the pressure
repeat for rest
should be around 150psi ideally and minimum of around 120
