Author Topic: Can i remove the carbon canister in a campus  (Read 2635 times)
« on: 19:38, Thu 14 July 2011 »
Its huge and has loads of gangley pipes. Can i chuck it all or will there be complications?
Cheers
Mark
megaflea
    • http://www.megaflea.net
Re: Can i remove the carbon canister in a campus
« Reply #1 on: 00:42, Sat 24 September 2011 »
I haven't removed the carbon canister from a campus, but have done on other vehicles,
Generally you need to make sure the vacuum pipe to the inlet is blocked (so you you don't create a leak run lean and idle extra high)if there is a breather to the fuel tank don't  block this up (as the fuel tank needs to vent (again not sure if there is on the campus) i'm sure someone will be able to give more details ;)
root@renault5gtt~]# echo "if you cant fix it" ; init 6 ; echo "it"
« Reply #2 on: 00:44, Sat 24 September 2011 »
Cheers, ive done all this now, very tidy in the bay. I had to block off 3 ports in the end.
