Has it just developed this since the headgasket went ?
Also what did Brigsy say about the carb, was it all good ?
I assume you have the dizzy drive gear in & not a tooth out, it's a right PITA to set sometimes, I used to use a headbolt IIRC & you need to make sure you get it so it's horizontal (or was it vertical, been a while) as you look at it but I forget which has to be left & which right as it has one cut out larger than the other doesn't it ?
I assume also you have tried a working carb or had wideband on it just to eliminate the carb.
