Author Topic: IceCream in expansion vessel.  (Read 13206 times)
Re: IceCream in expansion vessel.
« Reply #60 on: 09:13, Tue 16 August 2011 »
Ill sort the dizzy by turning the bolt hole the other way around.
Mayo is no more ! Well chuffed.
« Reply #61 on: 09:57, Tue 16 August 2011 »
Quote from: "andybond"
Told you it was head :mrgreen:
Yeah turn the dizzy bolt hole the other way.
Keep us posted
« Reply #62 on: 21:24, Tue 16 August 2011 »
I havent had time to have a look at the car tonight , but just a random thought...
The TDC sensor that goes over the flywheel. How does it work ? Electromagnetism ? Could this be interfered with due to excessive crud* on it ?
* crud is a highly technical version. Some maynot understand it.
« Reply #63 on: 22:46, Tue 16 August 2011 »
I'm sure it is basically a magnetic pickup. I suppose to much gunk could interfere?
The flywheel will have a missing tooth, or maybe a longer tooth then all the others to indicate when to spark.
« Reply #64 on: 21:13, Wed 17 August 2011 »
Not playing any more.
TOYS ARE OUT OF THE PRAM.
DAMMIT CAR JUST WORK !
« Reply #65 on: 21:16, Wed 17 August 2011 »
Made the dizzy adjustable , put it 180 out. Redid the ht leads.
Cannot get the car to idle sensibly. Sounds like it is idling on 3 cylinders.
2 minor electric shocks later from the ht leads ( even tho I had a thick towel over it ) and I still couldnt get it running right.
Move it back to the "fixed" position , and voila. Idles fine.
Couldnt take it out to boost ( where no doubt it will miss ) as kids in bed.
WTF?
« Reply #66 on: 20:28, Thu 18 August 2011 »
Fixed.
Reference pipe from top of FPR to the Carb top was cracked on the inside.
Cut it back , put it back on , job jobbed.
« Reply #67 on: 20:59, Thu 18 August 2011 »
Andy well done matey, bet your chuffed :mrgreen:
« Reply #68 on: 06:30, Fri 19 August 2011 »
Thats one way of describing it !
denty225
« Reply #69 on: 22:19, Fri 19 August 2011 »
FPR? What's that look like then?
« Reply #70 on: 10:05, Sat 20 August 2011 »
Quote from: "denty225"
Looks like this
« Reply #71 on: 10:59, Sat 20 August 2011 »
Follow the fuel pipe from the carb. You will find the FPR hiding down at the bottom of the drivers inner wing.
denty225
« Reply #72 on: 19:37, Sat 20 August 2011 »
:idea:  Fuel pressure regulator. Yeah I've had a fiddle with that a couple of times!
