Author Topic: Just bought another car...  (Read 17593 times)
Re: Just bought another car...
« Reply #45 on: 17:42, Tue 13 September 2011 »
Started on pulling the old lump out today, also mocked up the intercooler, fits perfectly, just need to make sure I can fit the pipe run on the drivers side..
« Reply #46 on: 19:41, Tue 13 September 2011 »
Whatever that bucket was for....it looks like you missed.  :lol:
Or is that just sweat from all the graft!
« Reply #47 on: 20:40, Tue 13 September 2011 »
I tried to catch the coolant, Edd China makes it look so east on Wheeler Dealers  :lol:
Just went fooking everywhere when I did it, then I had to lay in it   :idea:
« Reply #48 on: 17:11, Wed 28 September 2011 »
Bit the bullet & ordered a turbo from CR today, 600 :(  should be with me next week though  :D  .. then I'll be dropping the lump in as I have my engine mounts..  then it's just wiring it up  :shock:
pushbike88
« Reply #49 on: 18:19, Wed 28 September 2011 »
NICE CAR
« Reply #50 on: 19:43, Wed 28 September 2011 »
sounds like there are some good times ahead!  looking forward to seeing how it goes  8)
« Reply #51 on: 20:03, Fri 07 October 2011 »
Turbo turned up today, opened the box & instantly thought, hmmm, I think the front comp housing may be a bit big  :D
I was right, it won't fit the BB manifold  :lol:
Plan is buy a T25 flange off ebay & use it as a spacer or I'll be forced to hold out untill I can afford to have a tubular made up, prob not till christmas or new year though now if thats the case  :x
« Reply #52 on: 18:21, Fri 14 October 2011 »
Both front engine mounts are fabricated,  I will try a new rear one just so I can get the engine in & wiring done, can allways change it later.
Still waiting on my spacer for the turbo, hopefully that will allow it to fit or I will be buying a 200sx tubular & chopping it about, means I will need the downpipe as well I expect as the turbo will be top mounted...
Also welded the circlip in the valver box, that bugger won't pop now...
« Reply #53 on: 21:36, Fri 14 October 2011 »
That turbo is huge compared to my GT28.
Steve looking good hope welding the circlip makes a difference if not I can see you eating gearboxes.  :shock:
Are you beefing up that front engine mount as looks a little weak were it V's to the round engine rubber and joins
« Reply #54 on: 10:44, Sat 15 October 2011 »
The mount is made up from the OE mount, I may beef it up a bit but it's surprisingly strong, it will depend if it flexes or not.
« Reply #55 on: 19:58, Fri 28 October 2011 »
Finally getting there, got my spacer & some M10-M8 studs made up, now the turbo fits the manifold... Only time will tell if it clashes with the bulkhead or not  :lol:
Hope to put it all together & in over the next couple of weeks.
I also picked up a phase 1 172 box from the scrappers as well as the driveshafts, hubs & brakes, all for a bargain 150 ! Plan is to save up & quaiffe the 172 box.
I also have an RS chargecooler & got my lightened flywheel back & fitted the ecu & fed the wiring through into the engine bay ready to get started on that.
« Reply #56 on: 21:37, Fri 28 October 2011 »
whats the little switch for fella?
« Reply #57 on: 22:39, Fri 28 October 2011 »
Quote from: "small_all@hotmail.com"
I post up loads of piccies of nice big turbo's, machined flywheel, ecu & wiring & you pick out the switch that does F/A  :lol:
It had an alarm & that was the over ride switch I think.
Ridgeback
« Reply #58 on: 23:55, Fri 28 October 2011 »
That is going to be the mutts nuts.
« Reply #59 on: 10:40, Sat 29 October 2011 »
Quote from: "5teve L"
 :oops:  :cry:
