Author Topic: Need abit of help  (Read 2186 times)
kalve 5 gt tub
Need abit of help
« on: 21:04, Fri 10 June 2011 »
I have got a slight oil leak on my 5 but it seems to be comin from a hose of the front of the engine in between the block and the rad!! Is that the oil drain pipe? If so has anyone got a spare hangin around they want to sell?
owe
Re: Need abit of help
« Reply #1 on: 21:57, Fri 10 June 2011 »
can u take a picture? not sure if u cud be talkin about the turbo oil feed?
« Reply #2 on: 23:37, Fri 10 June 2011 »
I can think of a few in that area.
Oil feed for turbo.
Oil return from turbo.
Both pipes for the oil cooler.
A picture would help.  :idea:
kalve 5 gt tub
« Reply #3 on: 18:18, Sat 11 June 2011 »
Ill get 1 up asap so you can give me some advice
adscan
« Reply #4 on: 18:43, Thu 16 June 2011 »
i had a leak in the same place. it turned out to be the turbo oil feed. the banjo fitting was leaking.  :roll:
