GENERAL => General Chat => Topic started by: rsweeney on 13:37, Fri 15 April 2011
Title: wheel bearings
Post by: rsweeney on 13:37, Fri 15 April 2011
hey guys , renaults up and running insured it for a year today! only thing thats annoying me is when i drive there is a noise from the back of the car, the faster you drive the faster the sound gets. does this mean the wheel bearings need replacing, if not what else could it be ?
Title: Re: wheel bearings
Post by: fordy on 14:06, Fri 15 April 2011
new rear bearings needed fella
if your pads and discs need changing best do them together with the bearings as the new wheel bearings need to be pressed into the discs
Post by: rsweeney on 14:18, Fri 15 April 2011
ok but the rears are drums not disks so is it harder to do ?
will it need both sides doing and where can i go to get the bearings
Post by: fordy on 15:35, Fri 15 April 2011
drums? strange my 5 has discs
for the price of new bearings you might aswell do both of them
gsf is good for parts
Post by: rsweeney on 17:37, Fri 15 April 2011
cheers , and yeah turbo models have disks all round non turbos front disks + rear drums
will see what gsf want for rear bearings- will i need too use new circlips atall?
Post by: fordy on 17:51, Fri 15 April 2011
Quote from: "rsweeney"
ahh i see
new bearings should come with new clips :)
Post by: rsweeney on 18:02, Fri 15 April 2011
they only list rear bearings for turbo models
http://secure.gsfcarparts.com/shop/results.asp (http://secure.gsfcarparts.com/shop/results.asp)
Post by: markey mark (bd) on 18:04, Fri 15 April 2011
Rear bearings should be easy enough to source from any motor factor place, they may even be same as clio as they use drums also.
Post by: rsweeney on 18:21, Fri 15 April 2011
ok, will the bearings etc be the same as for the R5 turbo ?
Post by: markey mark (bd) on 18:29, Fri 15 April 2011
Not too sure mate, i recon gt turbo discs will have different design bearing compared to the campus drum but its worth checking
Post by: rsweeney on 18:51, Fri 15 April 2011
found some , these should shouldnt they ?
