GENERAL => General Chat => Topic started by: DanielSon-gtt on 22:38, Sat 28 February 2009
Do You Need Any Sealent On Any Gaskets At All Rockercover,waterpump,manifold..?
a little on water pump nothing on anything else
Ok Thanks I Ashume The Stuff From Cgb Good Anouth To Use
I've never used sealant on the water pump gasket, hasn't caused any problems. Not sure why that was suggested.
Just make sure the faces are clean.
If you have all the gaskets then you don't need sealant. You can use sealant on the water pump instead of the gasket...
