TECHNICAL ISSUES => Renault 5 GT Turbo => Topic started by: mat_pithers on 17:23, Sat 12 July 2008
im putting my engine back 2gether and cant rember where these go can any 1 take some pic's of there engine for me plz
(http://i301.photobucket.com/albums/nn41/mat_pithers1/car%20bits/IMG008.jpg)
(http://i301.photobucket.com/albums/nn41/mat_pithers1/car%20bits/IMG006.jpg)
m8, go on the "under the bonnet" section.
you may be able to see in the pic
the one on the left is from the carb to water pump or carb to inlet manifold ( i forget which) , the middle is from carb to turbo, the right hand one goes water pump to turbo.
thanks i can rember now u said just couldnt rember b4 thank u thatnk u verry much its been doing my head in all day
Just to confirm, the small one is carb to inlet manifold. 8)
just had a look at my engine and the only 1 i cant rember how it run's throw the engine bay is the 1 on the right i know where it go's but not where to run it
water pump to turbo or swirl pot to coolant tank
Thats the water pump to turbo pipe, it runs along the front of the engine by the rocker cover.
thats what i 4t but the middle 1 runs there its got the mounting points still on it and i cant find a pic any where its doing my head in all this just to get more bhp dont u just love the 5 turbo engine :wink:
They run on top of each other past the rocker cover.
ty i will sort them out 2moro and i will be sending u a pm in a bit as i will be wanting a new turbo if thats ok had a look at your list dont know what 1 to get tho
No probs.
go for the t28 thats what iam going to go for
i only want to run about 20psi for now in till i change the liners to steel 1s and forg cons and pistons ect some stuped cam
