TECHNICAL ISSUES => Renault 5 GT Turbo => Topic started by: Speedbird on 10:15, Wed 24 August 2016
Title: Fan not cutting in anymore
Post by: Speedbird on 10:15, Wed 24 August 2016
Hello,
The fan of my GT turbo stopped working. As described in the maintenance section, there can be several reasons for that. I would like to check the electrical wiring but I don't know where the thermal sensor is. Reparation manuals show schematics views but not the physical location of the sensor.
Can anyone tell me about it?
Thanks.
I will also check for blown fuse.
Title: Re: Fan not cutting in anymore
Post by: turbak on 12:48, Sat 27 August 2016
Termal sensor is on your right side of your radiator
Post by: Speedbird on 13:40, Tue 30 August 2016
OK, thanks.
So as can be seen on following picture:
(http://i63.tinypic.com/347v23p.png)
thermal sensor is the circled X symbol. And what about the T Thermostat? If the thermal sensor itself starts/stops the fan under coolant temperature control, what additionnal rule plays the Thermostat? Is is just a temperature probe?
