TECHNICAL ISSUES => Renault 5 GT Turbo => Topic started by: foxterier on 16:44, Sun 20 September 2015
Title: engine dropping revs
Post by: foxterier on 16:44, Sun 20 September 2015
Hallo guys
My r5 doesn't hold the revs constant when idle. It drops them significantly when cooling fan kicks in. Is it electrical problem: cooling fan, ECU,  anything else?  Many thanks
Title: Re: engine dropping revs
Post by: James5 on 20:17, Wed 23 September 2015
What does the car idle at RPM wise normally??
Sounds like the idle screw needs setting with a couple of electical item's on.
The R5 is basic it doesn't have an ECU it has an AEI unit which has a very basic ingition map on and that is it.
Post by: turbak on 13:24, Sat 27 August 2016
Ita normal when the fan start to work...
