TECHNICAL ISSUES => Renault 5 GT Turbo => Topic started by: alex.eyers1 on 22:55, Mon 10 June 2013
Title: Need help from phase 2 owner!
Post by: alex.eyers1 on 22:55, Mon 10 June 2013
Ok, so I am converting my phase 1 cooling system to phase 2 to install a water cooled turbo. I got all the parts now, and the job seems simple enough but I have never owned a phase two, and i am not exactly sure of the routing of the phase two cooling system.
The pictures below are what i think is going on from the water pump (in terms of outputs/inputs to components). I have also included a picture of the turbo and a header tank.
Can someone please confirm or correct my thinking of how it should be routed??? :?
Many Thanks
(http://i1094.photobucket.com/albums/i457/alexe9586/Renault%20Forum/Phase2WaterPumpMapped.jpg) (http://s1094.photobucket.com/user/alexe9586/media/Renault%20Forum/Phase2WaterPumpMapped.jpg.html)
(http://i1094.photobucket.com/albums/i457/alexe9586/Renault%20Forum/IMG_3629copy.jpg) (http://s1094.photobucket.com/user/alexe9586/media/Renault%20Forum/IMG_3629copy.jpg.html)
(http://i1094.photobucket.com/albums/i457/alexe9586/Renault%20Forum/Phse2Headercopy.jpg) (http://s1094.photobucket.com/user/alexe9586/media/Renault%20Forum/Phse2Headercopy.jpg.html)
Title: Re: Need help from phase 2 owner!
Post by: scratcher on 17:09, Tue 11 June 2013
From memory that looks right to me.
I done the same thing and converted my Phase 1 to the Phase 2 cooling system. I need to go and try starting it in a little bit so I'll double check  :)
Post by: alex.eyers1 on 23:58, Wed 12 June 2013
Thanks a lot :) . Just got to figure out where to mount the degassing chamber bracket now. I think il connect all the hoses, and see where it wants to go....
Il let you know how I get on. Cheers
Post by: Nrg on 21:19, Thu 20 June 2013
Degassing chamber mounts on drivers side headlight bottom bolt.
