TECHNICAL ISSUES => Renault 5 GT Turbo => Topic started by: adscan on 16:03, Mon 31 October 2011
Title: Wiring issue
Post by: adscan on 16:03, Mon 31 October 2011
MOT time is near so i thought i would swap out my washer jets for some that actually work. No problem there until i pressed the rear washer. Pressing this switch caused all my dials to die.
I checked the fuses and the one marked "STOP" had blown. What is this fuse for and why would this happen? Oh and my rear washer does not work. any common problems that i can check?
Also..will it fail the MOT for not having a working rear washer?
Title: Re: Wiring issue
Post by: karlr5 on 21:44, Mon 31 October 2011
your best bet is to chase the wiring back to the live and earth points,and as for the m.o.t remove the wiper if it does not work
Post by: Ash-Lee on 21:45, Mon 31 October 2011
Does the motor for the rear washer whirr away? Sounds like you have a wiring problem somewhere.
If it does whirr it might just be blocked, mine was full of gunk.
Post by: dj_craig_ on 22:39, Mon 31 October 2011
The fuse you mentioned is for the reversing light aswell, also check fuse number 4 wich is for rear screen wiper and washer
