TECHNICAL ISSUES => Renault 5 GT Turbo => Topic started by: mantasrb on 14:06, Mon 29 August 2011
bloody french bloody cars bloody hell.
how do i remove the dash? :)
Thanks
All i know is you have to remove the upper section of the steering column. Then start looking for screws to remove.
I've done it once before, but that was several years ago.
Okay cheers dude!
Remove all the lower parts below steering wheel and glove box, then fuse box. You then need to look for screws and according to haynes the lower grey section is one piece that is hooked onto the bulk head. You'll need dto remove the clocks too. And probably the steering wheel. And some skin off your knuckles. And get a swear box too! Good luck.
