Author Topic: anti-perc fan  (Read 1894 times)
L33GTT
anti-perc fan
« on: 01:15, Fri 07 January 2011 »
Im seen alot of R5s that have had this removed, Am i correct in stating this is the MAIN problem that causes the R5 to burst into flames?
Is removing the anti-perc fan a hard job?
Re: anti-perc fan
« Reply #1 on: 07:45, Fri 07 January 2011 »
You are correct. There have been reports of the anti perc fan turning into a flame thrower from Hades.
Piece of cake to remove. Few nuts n bolts and terminate the electrical ends.
L33GTT
Re: anti-perc fan
« Reply #2 on: 12:17, Fri 07 January 2011 »
Re: anti-perc fan
« Reply #3 on: 13:09, Fri 07 January 2011 »
L33GTT
Re: anti-perc fan
« Reply #4 on: 13:17, Fri 07 January 2011 »
Quote from: "James5"
http://www.youtube.com/watch?v=A5FWFBu4K_k
Seen that clip ages ago but never did watch it all! localish to me aswell :shock:
laura
Re: anti-perc fan
« Reply #5 on: 14:04, Fri 07 January 2011 »
ive run with out mine for years and no problems  :D
L33GTT
Re: anti-perc fan
« Reply #6 on: 16:32, Fri 07 January 2011 »
Cheers guys, ill make sure thats the first thing i remove when fitting the new engine..
Anyone and tips/guide to removing it?
Re: anti-perc fan
« Reply #7 on: 16:38, Fri 07 January 2011 »
You could just unplug it and make sure the ends are insulated, there's a constant 12v feed to it.
The motor is held in by a bracket on the inner arch, i think it's one bolt at one end and a hook on the other. The fuel line for the carb runs through the plastic tubing coming from the fan so keep that in mind before you start yanking at it.
