Author Topic: Norwegian Ph1 R5 GTT project  (Read 10548 times)
Re: Norwegian Ph1 R5 GTT project
« Reply #15 on: 17:46, Mon 18 October 2010 »
Some good progress there. Well done mate  :D
« Reply #16 on: 23:47, Tue 02 November 2010 »
i reckognise all that work. it takes time but its well worth it as i had to go through all of that on mine, altho i had to replace alot more wroten panels
lexgtturbo
« Reply #17 on: 11:38, Wed 15 December 2010 »
Sorry I haven't commented in this thread yet. Seems like its going to a great car when its done. Good to see that you are making progress and getting rid of the rust. I'm looking forward to seeing it complete. Keep up the good work.  :D
Benj88
« Reply #18 on: 17:35, Wed 15 December 2010 »
Great work so far keep it up
Rliaklev
« Reply #19 on: 18:50, Tue 28 December 2010 »
It takes definitely a lot of time, but it's worth it. Haven't done much lately except to prime and paint some parts  :)
Now I need to try the bumper, hood and headlights before painting. I will also see how the Mocal oil cooler will fit, but what do you think is the best mounting solution?
1985 Renault 5 GTT
lexgtturbo
« Reply #20 on: 10:48, Thu 30 December 2010 »
If you're not planning on a FMIC, then behind the grill would be a good place to mount it. Just in front of the radiator. That's where I would've placed it if I wanted to keep the original appearance of the 5 :)
« Reply #21 on: 11:08, Thu 30 December 2010 »
Quote from: "lexgtturbo"
I can recomend the grill area for an intercooler fitment, I can even fit the  OE Grill in place, I had to move the rad in slightly further in with a top bracket but temps are still good I run the low temp bits to be on the safe side am considering a better fan aswell at present
You can see my bracket in this pic
Rliaklev
« Reply #22 on: 16:43, Fri 31 December 2010 »
thanks for the reply :) I want to keep it as original as possible. I wonder if I should mount the oil cooler on the front beam or if I should make a mount to raise it. Will it get enough cooling if I mount it direkte on the front? :)
Like this:
1985 Renault 5 GTT
« Reply #23 on: 01:52, Wed 12 January 2011 »
hey mate,looking good mate getting rid of all the rust,have a look on my post,i have mounted my oil cooler on the front cross member with threaded rod,so it sits right in the opening for the front grill,you could also hang it from the bottom of the crossmember the same way,as long as its in a place to keep it cool  8)
Rliaklev
« Reply #24 on: 22:11, Wed 13 February 2013 »
Long time since last update now, but startup is comming fast :)
I will update with a lot of new pictures on sunday.
But I have one question, Where shall the hose circled with a red ring ends?
1985 Renault 5 GTT
« Reply #25 on: 23:14, Wed 13 February 2013 »
It is open at the end. If some part of the carb fails internally then fuel might come out of there so it needs to be away from anywhere hot.
I have mine down by the gearbox.
Rliaklev
« Reply #26 on: 19:14, Mon 18 February 2013 »
thanks Ash-Lee, that was to big help :)
1985 Renault 5 GTT
Jeff Ninebar
« Reply #27 on: 10:22, Tue 19 February 2013 »
Engine bay and all the steering parts look sweet, nice and new! The rocker cover is a nice touch to 8)
NorwegianGTE
« Reply #28 on: 19:06, Wed 06 March 2013 »
What can I say? That looks really good. Can't imagine how many hours spent?!
Veldig bra!  :mrgreen:
