Author Topic: My Raider... now F7P project...  (Read 47012 times)
Re: My Raider
« Reply #30 on: 09:34, Wed 15 September 2010 »
Quote from: "5teve L"
Plus I had to change the exhaust manifold as it had a stud snapped in it, nice one James  :P
 :oops:  Been like the for years with no probs  :D
Re: My Raider
« Reply #31 on: 08:46, Tue 05 October 2010 »
Engine finally in, just need to sort a few little probs like snapped one way valve on the inlet, fitted a new throttle cable so need to chop that down, sort the clutch pedal out as it has loads of slack, even with a new fork & bush, fit all hoses up & wire in the alternator, then just need to fire her up :)
Pi55ing down again here so looking like tomorrow or thurs now...  :cry:
Re: My Raider
« Reply #32 on: 09:10, Tue 05 October 2010 »
Steve,  I have a working one way valve here on my desk at work you can have, also got rear bumper lastic block in the car and front gearbox mount that might be of some use for you.
Will drop of laterz :D
Re: My Raider
« Reply #33 on: 14:22, Tue 12 October 2010 »
Currently waiting for a few parts to turn up that were missing off the engine  :roll:  (I blame James)
Sorted out my niggly clutch problem, turns out I needed to file 2mm off the stop  :roll:  re-fitted the FMIC as it was on the pi55  :roll:  & test fitted my new bumper I got off Marky Mark.
Once I get the car back I'll get round to fitting my saftey devices cage thats sitting in my garden..
FMIC before
After
Re: My Raider
« Reply #34 on: 15:27, Tue 12 October 2010 »
Looks like a good little project u got going there keep it up  :)   Keep the photos coming in i enjoy reading/seeing what people are up to.
Re: My Raider
« Reply #35 on: 15:58, Tue 12 October 2010 »
:lol:  Blame James
Stop making excuses for being slack and pull your finger out :lol:
I will try and find an oil sandwich plate bolt of your tonight matey.
Re: My Raider
« Reply #36 on: 09:00, Wed 13 October 2010 »
Found the bolt matey, left it on your doorstep this morning on my way through to work  :D
Re: My Raider
« Reply #37 on: 10:08, Wed 13 October 2010 »
hi steve was wondering what sort of boost your gonna be running?as im after a carb reciepe for mines,my spec is similar to yours im running the bbpt yellow spec engine with l&b and knifedged crank and flywheel and t28, just needing somewhere to start mate thanks baz 8)
Re: My Raider
« Reply #38 on: 11:26, Wed 13 October 2010 »
Hi Baz, every car is different mate so hard to say.. I'm going to try 24 psi manifold like my old car but it will depend if I can keep the carb bowl from emptying. Carb spec is 1.4 2nd stage, 120 main, 1.9 needle jet & I think it's either a 1mm or .9 A/C in there, you need to check with wideband though as will I.
On your spec I'd try 21psi manifold 1st (about 1.5 bar)
Re: My Raider
« Reply #39 on: 16:54, Wed 13 October 2010 »
cheers steve ill give it ago and see how it goes mate thanks for that,cant wait to see your motor when shes done,gonna be proper tasty keep us posted with the photos thanks again  8)
Re: My Raider
« Reply #40 on: 19:48, Thu 14 October 2010 »
It runs !!
& I think I have sorted the clutch, engine sounds nice & quiet as well.
She is still on axle stands untill I drop the oil & check for leaks etc. so hopefully by the weekend I will have the car back, rear arch is in the paint shop so I should be able to fit that back on next week, also fixed the sideskirt with the kit Bob @ CGB sells so that should stay on as well. All I need to do then is get the front bumper painted & fit the cage, job done :)
Re: My Raider
« Reply #41 on: 22:56, Thu 14 October 2010 »
Fecking good engine that am pretty jealous I didn't have enough cash for the engine aswell, still happy with the VNT though :).
Looking good matey can't wait to see it on the road :)
Re: My Raider
« Reply #42 on: 14:17, Fri 15 October 2010 »
Steve, Have you started prepping that bumper as it's looking more blue than black now :lol:
Re: My Raider
« Reply #43 on: 14:55, Fri 15 October 2010 »
Quote from: "James5"
Yeah I had some miami blue paint so gave it a quick spray over to see what it looked like,  I'll fill the little bits missing, fit the lower bars to hold it up & get it painted properly over the next few weeks.
H150GTT
Re: My Raider
« Reply #44 on: 00:14, Sat 16 October 2010 »
I like the meshed cut down version of the original grille. Looks smart
Would near put my old one back on again after looking at yours.
Tidy job lad!!  :mrgreen:
