Author Topic: My Raider... now F7P project...  (Read 47066 times)
Re: My Raider
« Reply #15 on: 17:19, Thu 26 August 2010 »
Quote from: "James5"
Quote from: "5teve L"
Faultless drive last night to Tadworth & back in the pi55ing rain, well apart from the alternator coming loose. Need some decent tyres on the 13's or some 15" rims for sure as it's sketchy in the wet  :shock:
Sketchy :lol:  you boys were alll over the place,
Yeah, fookin scary stuff, power on, go toward central reservation, power off toward lorry    :mrgreen:  :shock:
Re: My Raider
« Reply #16 on: 21:05, Fri 27 August 2010 »
Well done for turning this around so quickly mate  8)
I wish I had some of your enthusiasm!
Re: My Raider
« Reply #17 on: 22:02, Fri 27 August 2010 »
Lovin' it & I pick up the engine Monday, will try to fit it ASAP  :mrgreen:
Got new window rubbers to fit, new engine mounts, will prob get a helix paddle clutch & drop it in as well while I'm there & get that turbo pushing 1.5 bar boost.. I will then stick it on the rollers to see what she makes & then can't wait to get it to pod !
Re: My Raider
« Reply #18 on: 12:39, Sat 28 August 2010 »
I don't mind giving you a hand putting the engine in matey and getting the old one out :) let me know when you go to the rollers I will be up for some of that to :)
Re: My Raider
« Reply #19 on: 18:11, Mon 30 August 2010 »
400 mile 6 hr round trip & now I have MSM engine no 9  :twisted:
Paddle clutch to buy & then I'll drop it in !
Re: My Raider
« Reply #20 on: 20:49, Mon 30 August 2010 »
What spec is that engine Steve ?
Re: My Raider
« Reply #21 on: 22:20, Mon 30 August 2010 »
MSM engine no 9
Carb standard venturi, 120main. 1.9 needle, 1.0 a/c, 1.3 2nd stage
High Comp engine,
MSM Custom ported and polished head,
Matched manifolds
MSM Valve stem seals,
Mellior uprated H/G + 12.9 Head bolts torqued to 80nm,
Corteco bottom end gasket set,
New Pushrods,
New Cam followers
MSM 293 degree cam,
MSM High lift valve springs,
MSM Vernier,
MSM larger timing chain,
MSM High flow oil pump,
Total Seal piston rings,
MSM Steel Liners,
Tarabusi Pistons,
MSM L&B bottom end i think it may have been blue printed aswell,
.25 big end shells,
CTM 9 slot L&B flywheel,
Valeo green box clutch,
Breather mod to front of block,
Alloy carb top
T28 Turbo
Re: My Raider
« Reply #22 on: 13:49, Tue 31 August 2010 »
sounds crap  :shock:
 :D  :P
Re: My Raider
« Reply #23 on: 18:39, Tue 31 August 2010 »
Quote from: "andybond"
sounds crap  :shock:
 :D  :P
Yeah, prob will only get about 230 bhp out of it  :cry:
 :mrgreen:
Re: My Raider
« Reply #24 on: 19:17, Tue 31 August 2010 »
Dissapointing.
When you scrap it , ill have it to weigh it in ..
Re: My Raider
« Reply #25 on: 09:14, Fri 10 September 2010 »
Nearly ready to drop the engine in, clutch plate turned up yesterday...
Just need a dry day now  :roll:
Also dug out my old Renaultsport watch.. was thinking of making it into the clock in the car somehow..
Re: My Raider
« Reply #26 on: 09:17, Fri 10 September 2010 »
That clutch plate looks knackackered better let me test it out for you  :lol:
As said the other day matey I am more than happy to help with the engine in an eve to be honest we should be able to get an engine out and in within one eve anyway  :mrgreen:  and prob most bits bolted back on aswell ready to start.
Eve's are best for me as I really struggle daytimes at the weekends due to the Miss's and the kids :)
Re: My Raider
« Reply #27 on: 09:23, Fri 10 September 2010 »
Well I don't think this weekend will be very good anyway, I need to go to Marky Marks on Sat morning & then fit a fuel pump, new filter & AVCR in my old Evo & set it up for more boost. Then Sunday I'm out all day anyway... Will look at the weather & book you up  :mrgreen:
Re: My Raider
« Reply #28 on: 07:51, Mon 13 September 2010 »
Hope to get the engine in this week if the rain holds off.
Got new engine mounts to fit at the same time so should be alot better.
Re: My Raider
« Reply #29 on: 19:37, Tue 14 September 2010 »
Got the engine out but hit a slight setback, looks like I will need a new valeo cover & release bearing to put in :(
Plus I had to change the exhaust manifold as it had a stud snapped in it, nice one James  :P
Oh & one of the new engine mounts is different, the gearbox side for some reason doesn't have the metal block on it  :?
So need a clutch, rear arch, sideskirt clip kit & a new manifold gasket before I can get her back on the road !  :evil:
