Author Topic: My Raider... now F7P project...  (Read 46987 times)
« on: 14:25, Sat 21 August 2010 »
Thought I'd post up a small spec sheet for the new WIP>
Fairly standard at the mo but here is a brief run down.
T28
FMIC
2 1/4 exhaust
Samco water hoses
poly bushed arb
lowered 50mm
standard speedlines painted black.
Plans are 285 cam, more boost & some 195/45/13 tyres for the standard rims.
I plan on leaving the car as standard looking as poss.
Re: My Raider
« Reply #1 on: 21:24, Sat 21 August 2010 »
Cool you've returned to another 5...when did you buy this?  sounds like a nice car!  8)
Quote from: "5teve L"
T28
FMIC
2 1/4 exhaust
Samco water hoses
poly bushed arb
lowered 50mm
Re: My Raider
« Reply #2 on: 08:55, Sun 22 August 2010 »
Bought it last Monday :)
May have James5 old engine lined up to drop in  :twisted:  :mrgreen:
ARB's  & pads fitted so all MOT jobs are done now, will re-book tomorrow.
RE-fitted FMIC so the bumper fits a bit better now.
Re: My Raider
« Reply #3 on: 10:05, Sun 22 August 2010 »
Top man matey, hopefully as you say get MOT booked in quick so you can drive a 5 again.
And having my old engine will be fantastic matey, all the mods done for decent power and especially with the turbo you are running :mrgreen:
Re: My Raider
« Reply #4 on: 20:33, Mon 23 August 2010 »
Ok jobs done so far.
New front lines, discs & pads & calipers painted black
poly ARB bushes (old ones were about 3mm oversized, lol)
seatbelts sorted for MOT
dash sorted for MOT
new trackrod end
2 2nd hand tyres for the rear.
MOT booked back in Weds at 330pm so should be all ok & hope to pick up James5 old MSM engine in a week or so.
Jobs still to do.
Set the carb up as it's got a horrible lean spot mid revs if you hold it there, unless it's the dizzy cap & leads, I will be replacing the lot this week so we'll see.
Re: My Raider
« Reply #5 on: 21:14, Mon 23 August 2010 »
dash sorted for MOT
new trackrod end
Jobs still to do.
Steve could be a case of someone has knocked the dizzy gear out a tooth aswell, i thought I had a lean spot aswell but I decided to make the dizzy shaft adjustable so you can rotate the complete dizzy shaft with cap and leads on whilst the engine is runing hold it at the rpm you are having probs with and see if you can get it any better, could be a tooth or so out, don't forget that engine had a h/g done so could have been knocked out a tooth.
Re: My Raider
« Reply #6 on: 21:59, Mon 23 August 2010 »
Mark sorted the lump though didn't he, I can't see him doing that TBH.
Re: My Raider
« Reply #7 on: 22:50, Mon 23 August 2010 »
I don't think Mark done the H/G change on that engine I think Mark got it like that with the h/g change just done.
Re: My Raider
« Reply #8 on: 08:18, Wed 25 August 2010 »
Fingers crossed for the MOT today matey :)
Re: My Raider
« Reply #9 on: 08:30, Wed 25 August 2010 »
Well I have done all the bits needed for MOT so it should pass now.
Re: My Raider
« Reply #10 on: 09:06, Wed 25 August 2010 »
To right will be fine and looking forward to the drive tonight :) :mrgreen:
Be good to see you back behind the wheel of a laggy 5gtt
Re: My Raider
« Reply #11 on: 17:19, Wed 25 August 2010 »
Passed MOT & should be picking engine up Monday with any luck.. at least I can set the lag monster up a bit better then  :mrgreen:
Re: My Raider
« Reply #12 on: 21:11, Wed 25 August 2010 »
Congratulations.  8)
Re: My Raider
« Reply #13 on: 10:05, Thu 26 August 2010 »
Faultless drive last night to Tadworth & back in the pi55ing rain, well apart from the alternator coming loose. Need some decent tyres on the 13's or some 15" rims for sure as it's sketchy in the wet  :shock:
Re: My Raider
« Reply #14 on: 17:00, Thu 26 August 2010 »
Sketchy :lol:  you boys were alll over the place,
