Author Topic: My white 5 gtt  (Read 42515 times)
Re: My white 5 gtt
« Reply #105 on: 11:57, Sun 15 May 2011 »
ye nice turn around mate, whats the inside like? keep up the work
fordy
Re: My white 5 gtt
« Reply #106 on: 16:54, Sun 15 May 2011 »
Quote from: "small_all@hotmail.com"
insides are well erm ok ish for a cheap priced 5 but compared to the outside they are very poor
Rear seat cover as a cut in and i think maybe a fag burn not sure
Front seats bolsters are gone and a cut in one i think
The front frames are fecked as they dont move forward and backwards easily and everytime the Passenger seat is moved it looses another ball bearing from somewhere  :roll:
Dash has 2 holes either side of the column as one was for incar boost and other a random switch
Door cars the fabric is coming away and the carpet it just old and crap
The interior is my next point of attack after the engine is running sweet without fault.
also found out if i turn the rear wiper motor on the rev counter goes funny ever time the motor moves so i might just change the dash loom
Re: My white 5 gtt
« Reply #107 on: 18:24, Sun 15 May 2011 »
My rev counter jumps when i use the electric windows, thats with the engine off.   :roll:
Re: My white 5 gtt
« Reply #108 on: 21:27, Sun 15 May 2011 »
is this a common fault or summing both my cars have done it, it also dose it to the base line of music every now and again
fordy
Re: My white 5 gtt
« Reply #109 on: 23:16, Sat 21 May 2011 »
Still dont know if its fixed the lean issue as its not come out since last weekend but i know it is clean and polished  :mrgreen:
few of the bros mini aswell   :D
DanielSon-gtt
Re: My white 5 gtt
« Reply #110 on: 23:22, Sat 21 May 2011 »
Beautiful !!
Go Boost Or Go Home
Re: My white 5 gtt
« Reply #111 on: 23:27, Sat 21 May 2011 »
Very clean.  8)
gareth
Re: My white 5 gtt
« Reply #112 on: 00:30, Sun 22 May 2011 »
might be late might be pissed but wots an fpr go have'nt got one :?  :?
Re: My white 5 gtt
« Reply #113 on: 10:18, Sun 22 May 2011 »
Quote from: "gareth"
You should have one, if you follow the the fuel line for the carb you should find it hidden right down the bottom of the engine bay near the driver side inner wing.
gareth
Re: My white 5 gtt
« Reply #114 on: 14:02, Sun 22 May 2011 »
yer was just pissed mate soz
fordy
Re: My white 5 gtt
« Reply #115 on: 17:55, Sun 22 May 2011 »
cheers everyone still only done 330miles since rebuild, need to pile the miles on quicker for rolling road saturday at chav nationals (modified nationals)
Still got a persistant oil leak from the rocker cover fibre washers where someone has over tightened it before bending the cover inwards  :roll:
So i'm going all out this time.. I will fix this leak!  :twisted:  Going to get a new rocker cover, new studs, new nuts, new washers and new gasket all from renault and fit it when i reset the tappets in 200miles time  :D
Re: My white 5 gtt
« Reply #116 on: 18:06, Sun 22 May 2011 »
Quote from: "fordy"
Sounds like my rocker cover, i give the base of the nuts a good bit of sealant.
fordy
Re: My white 5 gtt
« Reply #117 on: 19:56, Sun 22 May 2011 »
sealer now that's a good idea
cheers matey will try that out , was going to try using rubber o rings instead of fibre washers but decided against it
Re: My white 5 gtt
« Reply #118 on: 16:28, Mon 23 May 2011 »
Looks stunnning, well done!
gt alan
Re: My white 5 gtt
« Reply #119 on: 19:04, Mon 23 May 2011 »
thats looks sweet mate ill be keeping a eye on this cant wait to see it all finished  :D
