Author Topic: my five.  (Read 21064 times)
Re: my five.
« Reply #75 on: 23:00, Sun 22 April 2012 »
Quote from: "hughesrobert13"
Quote from: "James5"
Quote from: "andybond"
Engine back in again , but rain stopped play before I could refit everything.
Also bought a VNT ..
Andy, you will love the VNT once you have it setup to how you want it, boost like a T2 yet the pull of a T3 you will run out of rev's before the VNT stops pulling aswell even with a cam
hi guys what car do you get a vnt from i know the vag use them is there one in particular that you use ? cheers rob
The one Andy has is custom made as was mine by Turbo development's a few peeps have made them themselves including me from other car's but it takes knowledge, skills and the tools to do it correctly.
DeanGT5
Re: my five.
« Reply #76 on: 19:28, Mon 23 April 2012 »
out of those 3 I have tools  :lol: maybe not the right tools though  :wink:
Re: my five.
« Reply #77 on: 21:37, Mon 07 May 2012 »
VNT fitted. Boy oh boy does it go !
PM#d James over on RTOC with 54.6 million questions.
Bet he loves me !
Re: my five.
« Reply #78 on: 17:07, Tue 08 May 2012 »
Bet he loves me !
Makes me feel wanted  :mrgreen:  pm away matey
DeanGT5
Re: my five.
« Reply #79 on: 21:22, Tue 08 May 2012 »
Im just waiting on my hoses to be made then ill be firing question your way too  :lol:
Re: my five.
« Reply #80 on: 22:38, Tue 08 May 2012 »
Quote from: "DeanGT5"
 :D  No probs matey fire away
Re: my five.
« Reply #81 on: 19:29, Wed 09 May 2012 »
Going to copy and paste the stuff I have fired James way , just incase anyone following this thread puts a VNT on their car.
Quote
Originally Posted by andybond
Vnts ! Where have they been all my renault 5 life ?
T2 spool , t3 pull !
2300 rpm it starts to pull hard. 5500rpm its going like a train and no sign of letting off.
This is at 11psi ( first time ! ) boost.
Can I ask you a few questions ?
How do I run more boost ? I have a bleed valve , but I would rather control via actuator. Can of lengthening rod rather than shortening it ?
Can I get the boost to come in lower ? I want popeye forarms from torquesteer!
I seem to have a small leak , like an exhaust leak between the core and the rear housing. Any ideas ?
VNT's are awesome matey best turbo for a 5, glad you like matey you will never go back to a normal turbo now
Originally Posted by James
Control it by Bleed valve matey these are not the same as conventional turbos when you do the rod up it effects the vnt in the wrong way and mess's the vane control.
You can make the boost come in early by undoing the bolt and undo the little hex head grub screw that the actuator arm sit's on this will bring boost in earlier  but you will need to shoten the actuator rod also this could be were thing's all go wrong, personally leave it as it is turn the boost up to say 20 to say 25psi and you will be wheel spinning from the off.
Re: my five.
« Reply #82 on: 19:31, Wed 09 May 2012 »
Quote
Need some more help mate. Got it set at 18psi. AFR are great ( 12.4 TOPS on sustained WOT )
However , I am getting only 1/2 psi +ive pressure until 4000rpm where it climbs to full 18psi.
What am I doing wrong ? Dont get me wrong , its fast , very fast. But its a t28 style delivery.
If I plant my foot at 3000rpm in any gear I just get the +ive 1 to 2 psi of pressure until those magic 4000rpm and then we are off like a scalded cat !
Afr's are to lean for a VNT matey you want to see 11.9 max  It's a safe zone as you may get some spiking turn down the boost so your max afr is as above.
It shouldn't be T28 delivery it should be 500rpm max between no boost and full boost although it maybe laggier in higher gears
ref what is happening did it do this with the 11psi it ran before or is this only as boost has been upped with bleed valve.
Re: my five.
« Reply #83 on: 19:31, Wed 09 May 2012 »
Oh this could be fun.
So undo the nut and change the vane thingy. Rod shorter or longer ?
rod will then go shorter matey turn the hex headed grub screw 2 full turns and then take for a drive and see what does, took me some time to sort mine out at one point I had it hitting full 25psi @ 1500rpm's
Re: my five.
« Reply #84 on: 20:32, Sat 12 May 2012 »
I have the five now boosting at 2500rpm and coming on boost hard.
I also like a spaz managed to hit 28psi. It flew.
For 8 seconds , and I shat me pants and pulled into a bus layby and turned the wick right down !
18 slightly spikey psi later and wheelspin in first is rampant ..
