Author Topic: Back in a 5.......  (Read 14969 times)
Re: Back in a 5.......
« Reply #30 on: 14:30, Mon 08 February 2010 »
They are like any car, if you geta  good one you get a good one; if it's bad it's bad!
Mine's somewhere in the middle :roll:  :mrgreen:
« Reply #31 on: 15:11, Mon 08 February 2010 »
8)  Do you get much lag? what kind of rpm does it really take off?
« Reply #32 on: 19:34, Mon 08 February 2010 »
no real lag at all mines a little lazy though (actuator) but just over 3k is full boost IIRC on a standard car, they pull like stink as well :)
« Reply #33 on: 19:30, Wed 10 February 2010 »
Quote from: "5teve L"
Blimey these Evo's are expensive to maintain lol.
Sounds like a wheel bearing has gone on the rear..that will be 160 then, may need a new thermostat or waterpump as well as the temp stays really low at the mo & the rad gets hot... hopefully get the car on Evoscan sometime soon to flash out the fault codes....
Still love it though :)
Steve I have an obd2 reader matey that may be able to get rid of some of your fault codes but unfortunstky it doesn't do all codes.
« Reply #34 on: 22:00, Wed 10 February 2010 »
You can buy the connectors and i'm sure someone in the Evo scene will have the appropriate software so you can connect it up to a PC.
Theres a load for my Saab, even ready made maps. Tempted to flash the 210BHP map on mine.  :twisted:
« Reply #35 on: 08:17, Thu 11 February 2010 »
Yeah there are the same for Evo's, ecuflash I think it's called.
Hopefully got a guy coming to take a look with evoscan soon, at least I'll know what probs I have or don't have.
Billiam
« Reply #36 on: 20:18, Sat 13 February 2010 »
Steve, if you're going for 1.5 bar, don't forget to change the fuel pump.  The standard one is only good for 1.3 bar, apparently.....
Been around these cars for too damn long!
« Reply #37 on: 18:08, Mon 15 February 2010 »
Slight update as i'll be adding some bits over the next week or so.. Parts on the way are..
Stainless manifold, 3" downpipe + de-cat, new turbo as i think mine has issues with the wastegate poppet not sealing, mishimoto (sp) alloy race radiator & some poly rear diff bushes & front ARB bushes (which look a right PITA to fit BTW), then see if I can sort the idle control out as it's playing up !
Prob get it geekmapped as well & run 1.4 bar boost
  :mrgreen:
« Reply #38 on: 18:15, Mon 15 February 2010 »
Alright steve .... Thought you had been kidnapped by the Japs :lol:
Hasnt taken you long to start tweeking the 5 then  :wink:
« Reply #39 on: 18:49, Mon 15 February 2010 »
Well I usually start with the suspension but this had it all done so it allows me to get into the serious stuff sooner  :twisted:
« Reply #40 on: 18:56, Mon 15 February 2010 »
atleast thats done then ,  :wink: What sort of power are you hoping to be gaining out of your new additions once mapped up Etc ? you going to have it live mapped ? Been hearing this is the way forward . so the ford scene says .... :roll:
« Reply #41 on: 19:42, Mon 15 February 2010 »
Yeah will prob just flash a map onto the rom using ecuflash. Will be hoping to hit around 350  with 1.4 bar, maybe 1.5 bar...
« Reply #42 on: 11:42, Tue 16 February 2010 »
Got my new evo 8 MR turbo today, same spec as my turbo but single flapper so sort of an upgrade :)
Also got my stainless manifold, to be fair it looks pretty well made considering I got it cheap..
Decat is in the car, downpipe on the way & ally rad should be here Friday as well.. think i'll be busy this weekend :)
James if ya fancy working on a different car pop round.lol.
« Reply #43 on: 16:34, Tue 16 February 2010 »
Would love to matey, really do like the look of your EVO hasn't taken you long to modify the engine :lol:
« Reply #44 on: 18:17, Tue 16 February 2010 »
Decat & new downpipe fitted, feels more responsive even at 0.4 bar  :roll:
Roll on the weekend & then it's onto the rad, turbo & manifold... & prob the boost cut, lol.
