Author Topic: NEW 5 Grey  (Read 40690 times)
jayy.cfg
Re: NEW 5 Grey
« Reply #15 on: 18:58, Fri 15 January 2010 »
yeah it needs tiding up and lil styling to look nice.
got a chrome rocker to go on. give that a clean before it goes in and some vacum colour hosing aswell
jayy.cfg
Re: NEW 5 Grey
« Reply #16 on: 14:53, Sun 17 January 2010 »
today got some work done on it.
- i/c found, put in place and strapped in.
- header tank put back in placed and checked it was in correctly by trojan.
- did some tiding up in the inside
- cleaned rubbish n leaves from scuttle panel
- waiting on boost hoses and air filter to fit them
Re: NEW 5 Grey
« Reply #17 on: 15:59, Sun 17 January 2010 »
Busy day then. Is it looking much tidier now?
I thought you had boost hoses from the bay pictures?
jayy.cfg
Re: NEW 5 Grey
« Reply #18 on: 16:14, Sun 17 January 2010 »
yeah did there OE 1's, doing a deal on some samco ones. just waiting on fone call for them.
still need to get rid of the unwanted pets left overs the old car has had in the bay. got rid of most of them tho :D
jayy.cfg
Re: NEW 5 Grey
« Reply #19 on: 23:18, Mon 18 January 2010 »
so i got my k&n cone filter today and sfs blue boost pipes which will go on tomorrow hopefully. what is your own opinion when it comes to turbo chatter , better noise when u have K&N or PiperX.
and now i have these sfs pipes do i not need the sense for the boost pipe or is there away u put the sensor on it .
Re: NEW 5 Grey
« Reply #20 on: 23:47, Mon 18 January 2010 »
The over boost sensor isn't essential. You can tuck them away somewhere, but make sure you tape the ends up properly, if they touch down it'll kill the spark.
jayy.cfg
Re: NEW 5 Grey
« Reply #21 on: 23:58, Mon 18 January 2010 »
okay i will tape them up and stick them to the wall somewhere so they dont catch anything.
where is best place for diff sizes jubilees ? sizes that fit, small / large hoses
Re: NEW 5 Grey
« Reply #22 on: 00:02, Tue 19 January 2010 »
My mate works in a Plumb Center and got me loads of different sized ones, much cheaper than anywhere else. Is there one in Stevenage? If not I could see if he'll order in the same as he got for me.
As for the chatter, I've had a K&N and 2 Ebay special filters and they all sounded pretty much the same, it was only different length pipe runs and bends that seemed to make a difference.
jayy.cfg
Re: NEW 5 Grey
« Reply #23 on: 07:41, Tue 19 January 2010 »
ill have a look down the local one across from mu work then. forgot bout somewhere like that
jayy.cfg
Re: NEW 5 Grey
« Reply #24 on: 07:47, Thu 21 January 2010 »
what have you guys used to block the dv hold on the samco hoses if you have them on your hosing ?
Re: NEW 5 Grey
« Reply #25 on: 08:16, Thu 21 January 2010 »
You can buy DV blanking plugs.
Or you can improvise, saw a bit off a broomstick.  :mrgreen:
jayy.cfg
Re: NEW 5 Grey
« Reply #26 on: 00:26, Fri 22 January 2010 »
Il have to order one of them this week or something. sfs performance dv holes. what size are they? does anyone know ? so i can get the right size blanker ?
jayy.cfg
Re: NEW 5 Grey
« Reply #27 on: 13:01, Sun 24 January 2010 »
looking around the car while cleaning out the spares i notice tho the sills are solid there is a little rust showing would this be mot failure atm my main thing is to get it started then after that the bodywork as it is in need of respray but if sills need replaying is how much is it roughly
Re: NEW 5 Grey
« Reply #28 on: 14:05, Sun 24 January 2010 »
Surface rust shouldn't be an issue, but it would be wise to treat it before it gets an worse.
If you can poke your fingers through it then it's almost certainly an MOT failure.  :lol:
jayy.cfg
Re: NEW 5 Grey
« Reply #29 on: 14:31, Sun 24 January 2010 »
yeah im intending on doing it all soon, need to get the other 5 sored aswell
